![]() Enthusiast ![]() ![]() Joined Feb 3, '04 From West Windsor, NJ Currently Offline Reputation: 3 (100%) ![]() |
1. Can I use the stock lug nuts?
2. Do I need hubcentric rings? 3. Why have I been reading on the forum that the offset is 45mm when on the box it says 40mm? thanks! |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From san antonio tx. Currently Offline Reputation: 12 (100%) ![]() |
1. Can I use the stock lug nuts? No.
2. Do I need hubcentric rings? no. 3. Why have I been reading on the forum that the offset is 45mm when on the box it says 40mm? dont know? I love mine. ![]() -------------------- Sorry, no animated sigs allowed.
1. Can I use the stock lug nuts? No. 2. Do I need hubcentric rings? no. 3. Why have I been reading on the forum that the offset is 45mm when on the box it says 40mm? dont know? I love mine. ![]() Thanks man. I can't wait to have them on the car. So I need tuner lug nuts and don't have to worry about hubcentric rings? I thought those were important... *edit: unless the bore is the same and they fit perfectly, lol (do they?) zero, what size tire are you using and do you have spacers? This post has been edited by Rider: May 20, 2008 - 1:18 AM |
bump... does anyone know what the center bore is on the stock wheels?
![]() Enthusiast ![]() ![]() ![]() Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) ![]() |
I may be wrong but I think you can use the stock lug nuts. Compared to the stock nuts the only difference seems to be that the tC nuts don't stick out as far. My tC rims came with the lug nuts so I used them. If anyone really needs to know I can pull one off and takes pics.
Lo-Fi Version | Time is now: February 18th, 2025 - 4:18 PM |
