Replacing catalytic converter?, Doing a full exhaust system |
Jun 24, 2008 - 5:57 PM |
Enthusiast Joined Feb 6, '08 From Oregon Currently Offline Reputation: 8 (100%) |
So i have been told something different from every shop i've talked to now and am getting a little fed up...
So some shops have told me that i wont need to buy a new catalytic converter Others say they will inspect it and see And the rest tell me i will HAVE to have a new one So for anyone who has done an exhaust system if you could give me your two cents on the matter it would be really appreciated:) car is in perfect running shape, and has 90xxx miles on it... -------------------- 1 JL 1,000/1v2
2 JL 12" W6v2 2 Focal 6.5 component 165a1 Kenwood DDX512 head unit Running 142.6db with the back seat up:) |
Jun 24, 2008 - 7:07 PM |
Enthusiast Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Hey man, are you talking about your top or bottom cat? I'm guessing your talking about the bottom since you want an exhuast. You shouldn't need it, they'll just have to add a bung for your second O2 sensor on the pipe after that area. Honestly you're not going to see any gains from removing it, I would just recommend getting a high flow cat for down there to help gaurantee that your second O2 sensor receives the correct readings and maintain legal emissions. Of course you could just have them make a delete pipe for you that way you can add a cat later to pass emissions and then remove it again easily. They have to add that bung for the sensor after that section anyway.
Jun 24, 2008 - 7:30 PM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
I think it depends on what size piping you are getting as well. For example, if you get a 3" pipe, I don't think they will be able to use your old cat because the inlet/outlet is alot smaller. You of course dont have to have one though. Just keep in mind that if your state is strict like mine (california) you will never pass smog with anything other than what is already there.
Jun 24, 2008 - 7:58 PM |
Unless you have a turbo, 3" is a little overkill.
Jun 24, 2008 - 8:42 PM |
Well i am planning on running 2.25 pipes...
So basically what i am gathering that if i do get a new one it should be a high flow cat? What would be the gain to not having a cat? It seems like alot of work to deal with to not have one... -------------------- 1 JL 1,000/1v2
Jun 24, 2008 - 9:52 PM |
Honestly there have been several magazine articles and the last I read they did a test on an Integra, and the most they could gather was 1hp more over a high flow cat if you go without. So given that it's only 1hp difference you might as well be smog legal.
Jun 25, 2008 - 12:42 AM |
Honestly there have been several magazine articles and the last I read they did a test on an Integra, and the most they could gather was 1hp more over a high flow cat if you go without. So given that it's only 1hp difference you might as well be smog legal. true story:) thanks alot -------------------- 1 JL 1,000/1v2
Jun 25, 2008 - 11:12 AM |
Enthusiast Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
dont mean to rob the thread...but how much hp gain will their be with a high flow cat?
Jun 28, 2008 - 2:25 PM |
dont mean to rob the thread...but how much hp gain will their be with a high flow cat? You don't gain much, it's more of just a principle kinda thing. If you're going to put an exhaust on your car to increase exhaust flow, then you might as well take care of every component you can. You're trying to open as much as you can. From what I remember a high flow cat only opens about .7hp, like I said before, it's not much but you wanna do it right. -------------------- |
Jun 28, 2008 - 2:38 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Removing the cat makes more difference than 1 HP.
Jun 28, 2008 - 3:44 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
The last time I saw someone ran without a cat, he shot fireballs out of his muffler. If your state doesn't require smog issues i say just for for a Test Pipe.
Jun 29, 2008 - 12:41 PM |
Ok, it didn't take me long to find and I recommend everyone take a look at this good read*. What I've been trying to say, and I admit I may have not worded it very well. The difference between a de-cat test pipe and an aftermarket cat is only 1hp. You'll see good gains from either one over stock. 1 extra hp just doesn't seem worth it to me, I don't want to have to change it out everytime I want to pass emissions. If my friends can pass with their SR 240s then I'm sure it's possible, it just depends on what state you live in and if you're willing to put up with the possible headache.
*http://www.importtuner.com/tech/impp_0610_...ters/index.html This post has been edited by GTS13: Jun 29, 2008 - 12:58 PM -------------------- |
Jun 29, 2008 - 3:46 PM |
Enthusiast Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
And there's another consideration -- you do breathe, right?
Lo-Fi Version | Time is now: January 10th, 2025 - 11:29 AM |
