![]() Enthusiast ![]() ![]() Joined Apr 23, '06 From Rochester, NY Currently Offline Reputation: 8 (100%) ![]() |
so what are the differences between the models/codes st202/st204/st205?
what does it mean? Erich |
Enthusiast ![]() ![]() Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) ![]() |
ST202 Liftback, Convertible SS-I (3S-FE), SS-II, SS-III, GT (3S-GE) Japan, Europe (Liftback & Convertible), Hong Kong & Singapore (GT Liftback only)
ST204 Coupe, Liftback, Convertible 5S-FE SX, ZR, GT North America (all body styles), Australia & New Zealand (Liftback only) ST205 Liftback 3S-GTE GT-Four Japan, Europe, Australia, New Zealand The ST205 is the AWD Turbo motor. The others are variations engine/trim of the FWD motor. -------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) ![]() |
http://en.wikipedia.org/wiki/3S-FE specs for each engine.
5SFE is 2.2 litre, 3SGE and 3SFE are both 2 litres but one having more power than the other and the 3S-GTE is a turbo charged 3SGE. |
thanks man, i just needed that cleared up.
Erich |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 14, '07 From Provo, UT USA Currently Offline Reputation: 25 (100%) ![]() |
don't forget the at200 also known as the extremely underpowered ST model 1.8l 7afe FWD
![]() Enthusiast ![]() ![]() ![]() Joined Jul 2, '08 From SoCal Currently Offline Reputation: 6 (100%) ![]() |
thanks, i was wondering what the hell mine was. pretty much you could say i'm clueless to the celica scene. |
don't mention it
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
also a couple of exterior differences bumbers, lights etc
![]() Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) ![]() |
so what are the differences between the models/codes st202/st204/st205? at200 is the st200 chassis with a 7A-FE front wheel drive power plant. Other than the power plant, it is the same chassis as the st200 but was only used for the Celica st200 chassis was used only on the Carina ED. It could take a 3S-GE 4WD power plant or a 3S-FE or 4S-FE power plant with front wheel drive st201 chassis was a slightly modified version of the st200 chassis for the Corona EXIV. This chassis was also used for the Carina ED in later years st202 is the main chassis for the Celica. It is a slightly modified st201 chassis to accept a 3S-GE without 4WD. Later years of the Carina ED and Corona EXIV adopted this chassis and thus were available with front wheel drive 3S-GE power plant. The Curren also used this chassis. st202c is the st202 converted to a convertible by ATC of America st203 is a slightly different chassis to accomodate the 4 wheel steering this model has. Also used by the 4WS model of the Carina ED. st204 is a slightly different chassis to accomodate the 5S-FE engine and transmission components. Only America (GT), Canada (GT-S) and Australia (SX and ZR) got Celica's using this chassis. st205 is a slightly different chassis with a larger transmission tunnel to accomodate the 4 wheel drive this model has. Carina ED was also available with this chassis and 4WD. st205 was the last Celica chassis before the 7th Gen, but not the last T20 chassis: http://en.wikipedia.org/wiki/Toyota_T2xx at200 is the st200 chassis with a 7A-FE front wheel drive power plant. Other than the power plant, it is the same chassis as the st200 but was only used for the Celica st200 chassis was used only on the Carina ED. It could take a 3S-GE 4WD power plant or a 3S-FE or 4S-FE power plant with front wheel drive Which is interesting as it would suggest that while the st202, st203 and st204 can't be converted to 4WD as the transmission tunnel isn't big enough, it may be possible to take the crappy at200 plus parts from a st200 Carina ED and convert the Celica to 4WD without serious mods to the chassis. Plus, a non-turbo 4WD has a certain appeal from an insurance viewpoint. This post has been edited by BloodyStupidDavey: Jul 8, 2008 - 2:27 AM -------------------- Davey
Items for sale |
double post - please delete
This post has been edited by BloodyStupidDavey: Jul 8, 2008 - 2:25 AM -------------------- Davey
Items for sale |
Enthusiast Joined Aug 25, '08 From georgia Currently Offline Reputation: 0 (0%) ![]() |
wut about the suspension because ive seen a few struts with three bolts on the rear... but my st204 has 2 bolt holding the strut on the rear where it connects to the chassis!!
Enthusiast ![]() ![]() Joined Jun 18, '08 Currently Offline Reputation: 3 (100%) ![]() |
Don't forget about the ST206 ST207 aka Toyota Curren
Enthusiast Joined Mar 17, '09 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
so what are the differences between the models/codes st202/st204/st205? at200 is the st200 chassis with a 7A-FE front wheel drive power plant. Other than the power plant, it is the same chassis as the st200 but was only used for the Celica st200 chassis was used only on the Carina ED. It could take a 3S-GE 4WD power plant or a 3S-FE or 4S-FE power plant with front wheel drive st201 chassis was a slightly modified version of the st200 chassis for the Corona EXIV. This chassis was also used for the Carina ED in later years st202 is the main chassis for the Celica. It is a slightly modified st201 chassis to accept a 3S-GE without 4WD. Later years of the Carina ED and Corona EXIV adopted this chassis and thus were available with front wheel drive 3S-GE power plant. The Curren also used this chassis. st202c is the st202 converted to a convertible by ATC of America st203 is a slightly different chassis to accomodate the 4 wheel steering this model has. Also used by the 4WS model of the Carina ED. st204 is a slightly different chassis to accomodate the 5S-FE engine and transmission components. Only America (GT), Canada (GT-S) and Australia (SX and ZR) got Celica's using this chassis. st205 is a slightly different chassis with a larger transmission tunnel to accomodate the 4 wheel drive this model has. Carina ED was also available with this chassis and 4WD. st205 was the last Celica chassis before the 7th Gen, but not the last T20 chassis: http://en.wikipedia.org/wiki/Toyota_T2xx at200 is the st200 chassis with a 7A-FE front wheel drive power plant. Other than the power plant, it is the same chassis as the st200 but was only used for the Celica st200 chassis was used only on the Carina ED. It could take a 3S-GE 4WD power plant or a 3S-FE or 4S-FE power plant with front wheel drive Which is interesting as it would suggest that while the st202, st203 and st204 can't be converted to 4WD as the transmission tunnel isn't big enough, it may be possible to take the crappy at200 plus parts from a st200 Carina ED and convert the Celica to 4WD without serious mods to the chassis. Plus, a non-turbo 4WD has a certain appeal from an insurance viewpoint. BSD that's more information than what I've been able to find on Google about the ST models. Sorry I know this isn't to do with 6GC but I have a '96 Carina ED ST-200 and wanted to try and change out the FWD 4S-FE engine for the 4WD ST205 3S-GTE (gen 3) from a Celica GT4, as the Carina ED was intended to be a 4-door Celica. Obviously such a conversion wouldn't be cheap as the EDs never had the 3S-GTE, the most they had was the 3S-GE and 3S-FE. Do you know how such a conversion would be possible as I'm only really starting to get familiar with these cars? The most I've done with this car is replace the right rear door, stripping all the parts out of the old door and fitting them into the replacement one. I haven't exactly done much else. Once again sorry for being somewhat off-topic but this is the most I've been able to find on the differences in sub-models. Google hasn't been so useful so far, or maybe I'm searching wrong. This post has been edited by Dickson: Mar 17, 2009 - 5:53 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
hmm can we get some curb weights for for each model. the at200, st202, st204, st205.
Is the st202 with 3sge beams and ss suspension lighter than st202 with regular 3sge and macpherson suspension?? -------------------- Group buy to replicate Narrow E series transaxle parts
hmm SS-III BEAMS is 10kg heavier than the SS-II or so says:
'96 SS-II 1200kg http://www.cars-directory.net/specs/toyota...ca/1996_6/5740/ '99 SS-III BEAMS 1210kg http://www.cars-directory.net/specs/toyota...ca/1999_1/5724/ '96 SS-III 1210kg '99 SS-II BEAMS 1200kg In that both are maunals how about autos? '96 SS-II auto 1230kg '96 SS-III auto 1240kg '99 SS-II BEAMS auto 1230kg '99 SS-III BEAMS auto 1240kg This post has been edited by Rusty: Mar 18, 2009 - 1:13 AM -------------------- |
[quote name='Rusty' date='Mar 18, 2009 - 1:09 AM' post='762517']
hmm SS-III BEAMS is 10kg heavier than the SS-II or so says: '96 SS-II 1200kg http://www.cars-directory.net/specs/toyota...ca/1996_6/5740/ '99 SS-III BEAMS 1210kg http://www.cars-directory.net/specs/toyota...ca/1999_1/5724/ '96 SS-II 1200kg '99 SS-III BEAMS 1210kg hmm ok i got you thanks for that info. ![]() -------------------- Group buy to replicate Narrow E series transaxle parts
thats ok, I found it quite interesting about the amount of difference in weight which I would have though would have been the same.
Lo-Fi Version | Time is now: February 18th, 2025 - 4:20 AM |
