st185 conversion |
st185 conversion |
Jul 10, 2008 - 2:15 PM |
Enthusiast Joined Sep 13, '07 From upstate ny Currently Offline Reputation: 1 (100%) |
has any 1 ever done a awd conversion into a st from a st185? if so wat kinda fab work is involved? is there welding,drilling.... and does the st have the clearence for a driveshaft? i found a parts car with the engine torn apart.
Jul 10, 2008 - 3:08 PM |
Enthusiast Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
search is your friend
-------------------- Kawi Love |
Jul 10, 2008 - 5:43 PM |
has any 1 ever done a awd conversion into a st from a st185? if so wat kinda fab work is involved? is there welding,drilling.... and does the st have the clearence for a driveshaft? i found a parts car with the engine torn apart. no. what kinda fab work? serious fab work. custom subframe and mounting brackets in the rear. motor mount swap in the engine bay (easy), LOTS of welding and LOTS of making your own structures. you have to cut out the spare tire well + custom fuel cell & gas lines ST should have enough clearance for drive shaft. |
Jul 10, 2008 - 6:13 PM |
has any 1 ever done a awd conversion into a st from a st185? if so wat kinda fab work is involved? is there welding,drilling.... and does the st have the clearence for a driveshaft? i found a parts car with the engine torn apart. no. what kinda fab work? serious fab work. custom subframe and mounting brackets in the rear. motor mount swap in the engine bay (easy), LOTS of welding and LOTS of making your own structures. you have to cut out the spare tire well + custom fuel cell & gas lines ST should have enough clearance for drive shaft. but will the axels work? i dont kno if the wheel base is the same or if the axels will fit (wider body?). i havent had the time to gogle this yet This post has been edited by sous710: Jul 10, 2008 - 6:14 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:44 AM |
