Enthusiast Joined Jul 11, '08 From usa Currently Offline Reputation: 0 (0%) ![]() |
Hello all, this is my first post since I just recently purchased my '95 GT Convertible. I'm learning a lot from the resources on this board and it's already helped me repair the automatic top. Now I'm trying to troubleshoot the passenger side automatic quarter window. It will roll down fine, but when it tries to go up it won't budge, it doesn't even make a noise. I thought it might be the regulator at first, but I've been able to rig up a wire bridge that allowed me to use the driver side electrical path (bridge went from driver side rear quarter window wiring harness to the passenger side power window motor) and the window went up fine, whew not the regulator. But my question is this; does each quarter window have its own relay or is there a single relay for both? The wiring diagram seems to suggest that there is only one, but I'm definately not an electrical expert. I'm trying to determine if I know for sure that the passenger side switch is bad or if there is some other broken component along the signal path. Toyota's infinite wisdom resulted in different wiring harnesses for the driver and passenger side quarter window switches so I can't just switch them out and try it. Thank you all for the help.
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:59 AM |
