> KYB GR-2's, Got a question about these
post Sep 14, 2003 - 4:33 PM
jrg
Joined Apr 30, '03
From Mississippi
I just bought a set of Sportline's, and I also ordered the KYB GR-2's. I bought these from tirerack.com. But when I bought them, I only saw cartridge inserts for the front and strut housings for the rear. Am I missing something? Is the front not the same as the rear? Also, do I need the alignment kit? I've heard that I don't.
post Sep 14, 2003 - 5:47 PM
FallenHero
Joined Dec 26, '02
From Alabama
The cartridges slip into the stock strut housings. it's no big deal
I really don't think you will need an alignment kit for a 1.5" drop. When you have them installed, just get them to allign the wheels, and you'll be good.
Jon
post Sep 14, 2003 - 7:15 PM
macavely
Joined Nov 4, '02
QUOTE (jrg @ Sep 14, 2003 - 4:33 PM)
they use cartridges for the fron because it's cheaper then just getting the whole assmable.. when you change out the stocks for the KYB you'll see the diffrence.. if you do it your self.. and no if your useing 1.5" drop you don't need an aligment kit but it's a good idea to get one.. better safe the sorry cause 1.5" is the cut off for getting a aligment kit... 1.6" and more you do need and aligment kit..
post Sep 14, 2003 - 8:15 PM
3TST
Joined Sep 27, '02
From UK
I don't think you'll need an aligment kit.
I have KYB GR-2's / B+G springs with a 1.6" drop and its fine.
The only problem I came across was taking the old cartridges out of the front strut assembly. I couldn't undo the retaining "plastic" nut so I got a local garage to do it for me. (He charged me $5 to remove the old cartridges and put the new ones in).
You'll need a spring compressor as well.
This post has been edited by vphmc: Sep 14, 2003 - 8:16 PM
Lo-Fi Version Time is now: February 17th, 2025 - 12:19 PM
