aem wideband?, question |
Jul 28, 2008 - 10:20 PM |
Enthusiast Joined Jun 10, '08 From Virginia beach Currently Offline Reputation: 8 (100%) |
hey guys, quick question. somebody is sellin their wideband o2 sensor, (AEM UEGO) for 200$ im boosting my 7afe and will probably look into getting one. my two questions are... is it necessary? and secondly, does it work with a gauge other than the AEM gauge that comes with it? i have a 3 gauge pillar and my AFR matches the rest, and want to use it. will it work with my AFR gauge i currently have?
thanks guys. and quick feedback would be awesome! im supposed to buy it tomorrow morning! thanks allen -------------------- |
Jul 28, 2008 - 10:40 PM |
the sensor itself will work with just about any wideband display.
yes, you need one. -------------------- |
Jul 28, 2008 - 10:45 PM |
it's nessessary.
but I'm not sure a generic afr gauge is designed to work with a wideband sensor/controller. -------------------- |
Jul 28, 2008 - 10:52 PM |
ive got the AFR from prosportgauges. it says it will work with any wideband with an output of 0-5v but bosch isnt compatible. one of the AEM ones are a bosch replacement. hopefully ill get lucky? lol
Jul 28, 2008 - 11:23 PM |
the AEM UEGO uses a bosch sensor.
Jul 28, 2008 - 11:54 PM |
*NEW FEATURE*
This gauge can be set to read narrow band or wideband (0-5v) with the flick of a switch in the back of the gauge. That means that you can now use this gauge with your stock narrow band O2 sensor or use it with a control unit like innovate to display a 0-5v signal. NOTE: This cannot be used as a stand along wideband AFR with a bosch wideband 5 wire heated O2 sensor unless you are using a controller! (Our complete wideband AFR gauge is due out end of June) thats the notice it gives me for the gauge i bought. batman, since you know more about the AEM sensor. is it compatible with working with this gauge i have? -------------------- |
Lo-Fi Version | Time is now: December 4th, 2024 - 8:49 AM |
