> rusty door bottoms..., ..and how to stop it-suggestions please?
post Jul 31, 2008 - 11:35 AM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
As you may or may not know the doors on 6gens have a drainage hole at the bottom which is a really bad idea as water collects in the bottom door seam and causes the dreaded rust. Mine have a small amount on the surface and I would like to know how to stop it getting any worse. Is it safe to block the hole up or will that cause serious damage?
Any ideas for members will be much appreciated, thanks
post Jul 31, 2008 - 11:41 AM
frisp
Joined Jan 2, '08
From Scotland
The rust normally gets hold because the drains get blocked. Both my doors have the dreaded tin worm. If it's not too bad, sand/grind as much off as you can. Treat with a good rust treatment/convertor & repaint. You could use waxoil or similar after treating/painting too. Just make sure the drain holes stay clear.
Going have to change both my doors, will be stripping to bare metal and painting with POR-15 before paint/waxoil.
Hope that helps.
Regards
frisp
HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier
Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's
JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6
To be done....
Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads
post Jul 31, 2008 - 11:49 AM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
Hi, and thanks for the suggestions. Luckily the car was only imported 5 years ago so isn't too bad wink.gif
I was wondering wether to fill the seam with filler so the water doesn't collect in there as well? good idea?
This post has been edited by hardcoreproducer: Jul 31, 2008 - 11:52 AM
post Jul 31, 2008 - 11:50 AM
frisp
Joined Jan 2, '08
From Scotland
Only a good idea if you are sure there in no rust in the seams already. though, it will slow it down a bit if it's already present.
Regards
frisp
To be done....
post Jul 31, 2008 - 9:51 PM
http://www.6gc.net/forums/index.php?showtopic=23629
more info and solutions.
Lo-Fi Version Time is now: November 24th, 2024 - 12:59 AM
