Enthusiast ![]() ![]() ![]() Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) ![]() |
So i found a 99 Camry solora tranny for a good deal, i was just asking if it would work with my 3s swap, now i believe its a e153 tranny right? so it should bolt right on the the 3s, also i would use the camry inners and the set of outers that i have on my car as well, is there a advantage with the camry solora tranny, like gearing, lsd?
gearing, durability, yes.
you would need MR2 turbo inners and all-trac outers, and at least a 1/2" spacer for the pass side axle. As for mounts...st205 rear w/bracket, st205 driver's side w/bracket, and you can use your GT/ST front mount/bracket. edit, and the st205 shifter cables. This post has been edited by Batman722: Jul 31, 2008 - 5:12 PM -------------------- |
i have all those right now for my mr2 tranny, but i was just making sure that its gonna be plug and play
I didn't know you had the mr2 tranny, yes it should be plug and play.
kk thanks, btw i can still use the same clutch right
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) ![]() |
kk thanks, btw i can still use the same clutch right i say yes dont have time to double check, will look into later This post has been edited by devilsden97: Aug 1, 2008 - 8:57 AM -------------------- ![]() Kawi Love |
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
You probably already know this... but make sure it is a V6 Solara trans, not the 4-cyl trans...
![]() -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
it came off a 3.0 solora,
what about the gear ratios on this tranny, is it the same as the s54 , you know high revs on 5th gear while doing 70?
can i use it on the 5s? This post has been edited by njccmd2002: Aug 5, 2008 - 8:45 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
what about the gear ratios on this tranny, is it the same as the s54 , you know high revs on 5th gear while doing 70? can i use it on the 5s? way to jack the mans thread.. lol jk To be totally honest, if u guys have specific questions, a good person to ask is Silver94celicaowner. He did a 3rd gen swap in his car, with an e513 (non-lsd) tranny out of a Camry. He should know a fair amount about its capabilities, and its compatabilities. .....If hes ever on. -------------------- ![]() Kawi Love |
what about the gear ratios on this tranny, is it the same as the s54 , you know high revs on 5th gear while doing 70? can i use it on the 5s? way to jack the mans thread.. lol jk To be totally honest, if u guys have specific questions, a good person to ask is Silver94celicaowner. He did a 3rd gen swap in his car, with an e513 (non-lsd) tranny out of a Camry. He should know a fair amount about its capabilities, and its compatabilities. .....If hes ever on. hey ![]() -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Lo-Fi Version | Time is now: February 17th, 2025 - 3:37 PM |
