Enthusiast Joined Jul 6, '08 From Burlington, VT Currently Offline Reputation: 1 (100%) ![]() |
Last fall i patched the bottoms of my doors up really roughly just so my car would pass inspection and not rust through in the 683210789748935 feet of snow we got this winter. Anyways, I went back to attempt to do a more thorough job of it and found that the rust problem has grown to a more extreme level. Personally i think i need some new doors if i want to be rid of this problem. Judging by the pictures, what do you think?
![]() ![]() ![]() This post has been edited by jophish: Aug 11, 2008 - 9:06 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) ![]() |
Ive got the exact same problem, your best choice now is to cut a piece off the bottom and weld a new piece of metal to it, or get new (used)doors.
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) ![]() |
yea ..Same here..Find a junk yard with a set of good doors, I got a set 150.00
![]() Enthusiast ![]() ![]() ![]() Joined Feb 10, '06 From Knoxville, TN Currently Offline Reputation: 8 (100%) ![]() |
I have a spare set I need to get rid of. Mikecelica has first dibs but if things don't work out they will still be up.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
scrap the doors all together and replace them. You can patch and weld etc. all you want but the rust is basically always going to get worse. If it's bad enough you won't have enough good metal to weld to in the first place anyhow!
Damn the VT winters... I had an '87 Pathfinder that originated in VT. That thing was so rusted out that stuff was basically just fused together by rust. But man did it run great! -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
Buy some used doors in good shape and cover the bottoms and inside seam with Por 15 before you have them painted. That should hold off the rust for another 15 years.
Lo-Fi Version | Time is now: February 13th, 2025 - 12:04 PM |
