![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
As simple as it may look, wheel spacers are dangerous. Below is the conversation between two mech gurus.
-------- From: pantera@shiseis.com (Shane F. Ingate) Subject: Re: Wheel Spacers Date: Thu, 12 Nov 1998 12:18:30 +0000 -------------------------------------------------------------------------------- All, The following is an excellent discussion on the use of wheel spacers by two mechanical gurus of the NorCal Shelby Club, Don Wollasen and Scott Griffith (Skod). The discussion took place on Jun 14, 1998 Shane ------------------ Dave Dwelley asked: -------------------------- Why are wheel manufacturers so uptight about wheel spacers? I'm at the point where I'm buying wheels for the Falcon, and because it's fenders are so tight, I'll need to get the offset just right - that almost assures I'll need wheel spacers. I can see how a 2" spacer might overstress the wheel studs, but 1/8"? I don't even lose the ability to center the wheel on the axle center! Not that most of the aftermarket wheels seem to care - they all seem to use the lugs, not the center, to align to the hub. -------------------- Scott Griffith replied: --------------------- The same reason that we frown so heavily on wheel spacers on track cars: they really *are* dangerous, and they really do create additional loadings in the studs that can quickly exceed the ultimate tensile or ultimate bending strength of the studs and lead to an outright, catastophic failure. When you have a wheel bolted directly to a rotor (or a drum) with no spacer, there is only one single shear plane. If there is slippage at that plane, you induce a bending load in the stud. You also increase the tension load in the stud by a value proportional to the sine of the bend angle. However, the bending moment is applied essentially right at the stud root- the loads are contained to the shear plane, so the total bending load is controllable, and relatively small, since the offset is nearly zero. It is essentially a pure shear load. But if you interpose a spacer, then there are now two shear planes. The makes slippage of the wheel with respect to the drum/rotor much more likely with braking or drive loads, since there are two sets of surfaces to clamp. But much worse than that, the bending load is no longer applied right at the root of the stud. It is now applied whatever the spacer thickness is *away* from the stud root. The bending load is thus proportional to the spacer thickness, and if that thichkess is nonzero, the load goes up *fast*. Even worse, the increase in the tension load is proportional to the square of the sine of the bend angle (if I remember correctly), and that value goes up *unbelievably* fast with increasing bend angle. At that point, the only question is whether the stud will fail from accelerated fatigue cracking due to the bending loads, or just fail in a brittle mode from the tension overload. This is not a contest you want taking place on your car. Bottom line is that running a 1/8" spacer probably reduces the ultimate strength of the assembly by a factor of 2, and the fatigue life goes to hell as well. With a 1/2" spacer, the loads can exceed the ultimate strength of even the best quality studs, and the fatigue life is nonexistent. I have seen an instance where a friend of mine (a chassis engineer at Ford, in fact) sheared 4 of the 5 ARP 180,000psi studs on one front corner in a *single stop* with a 1/2" spacer, even when they were properly torqued- just to prove the point of the risks involved in running spacers. Moroso studs, or some of the other somewhat brittle "race" studs, have no chance whatsoever when run with a thick spacer. Don't run loose spacers on the front end, at all, ever, on a track car. They might be acceptable on the rear (since the braking loads are so much less), or on a delicately-driven street car, but not one that I own! For a car that will see threshold braking into a corner where a stud failure is likely to result in a trip to the toolies, they are just flat unacceptable. While we do not have a blanket prohibiton against wheel spacers in the tech rules, there are solid engineering reasons to avoid them like the plague. We've been trying to slowly educate people about them as time goes on and cars go faster, one on one- but this is a good time to bring it up again. If somebody shows up at Nini Nats with inch-thick spacers, we'd probably park them. It's always fun to look at Super Ford, and see pictures of the drag racers who've blown their rear studs out at launch, and try to blame the studs... If you absolutely, positively *must* run spacers to make the stackup work on your car, you must machine them for some hardware (perhaps reamed dowels and countersunk socket-head cap screws) that you can use to rigidly lock out one of the two shear planes. Studs will handle single-shear-plane loadings all day long, if properly torqued, but they die *fast* with two shear planes and the resulting increase in bending and tension loads. One of these days I'll pull out a chunk of graph paper and redo the derivation of the bending/tension load changes for an example case. I did it once before, and the numbers really are mind-boggling. Maybe I can find my notes- but it was 10 years ago... -skod ----------------------- Don Wollasen replied: ------------------------ Good post, Skod. However, a few comments from the peanut gallery. IF the studs are well torqued, then the wheel to hub is (well, SHOULD be) attached by FRICTION and NOT dependent on the shear or bending load on the studs. i.e. if the spacer doesn't flex any (it does a little) then there should be no shear load or bending load on the stud. What this means to non-Engineer types, is that you want to squeeze the wheel so that it sticks to the hub with friction. So, if you torque the nut to the stud and place 50,000 pounds of tensile force on the stud ... which squeezes the wheel to the hub, then if the friction coefficient between the wheel and hub is 0.9, then you can put 40,000 pounds of shear force (per stud) on the wheel to hub interface. If the friction coefficient between the spacer and the wheel is 0.9, then you are down to 36,000 pounds of shear capability. So ... the message here with this comment is that the surface between the hub and the spacer and the wheel should not be shiny, it should have surface roughness ... like normal machine marks. It is, however, better to think of all metals as plastic and assume that they do flex some. Since the wheel and spacer does flex a bit, the stud will bend a bit ... and this will be true even with no spacer. As Skod points out, any bending of the wheel stud is NOT good. If you use really brittle studs (as Skod pointed out), they are more likely to break. My point being here that the discipline of checking wheel bolt(or nut) torque before each run on a race car is maybe tedious, but is good practice if you don't want the wheels to fall off. The fact the studs do break with bigger spacers as pointed out by Skod, should be evidence that Engineering pontification notwithstanding, it is an issue. I run 1/4" spacers on the front end of my Jensen Healey. Of couse it has 500 pounds/wheel with 4 of the same ARP studs you Mustang guys use 5 of on your well prepared track cars with 900 pounds/wheel. So ... if you are gonna hafta use a 1/2" spacer, then I would recommend that the spacer be: a) dowelled to the wheel b) screwed to the wheel (with aluminum wheels use coarse pitch threads because the aluminum can't stand a lot of torque anyway). Note, this is just to get the spacer to the wheel in close contact and keep it there when you take the wheel off, the real squeeze needs to come from the wheel studs-bolts when you bolt the wheel to the hub. c) Spacer Locktited or epoxied to the wheel (a "permanent" attachment). Or in other words, you should make sure the spacer is as much a part of the wheel as you can. Then you approach having only one friction shear surface (the one from the hub to the spacer). This will be not quite as good as having no spacer. Of course this is NOT as good as being able to obtain a wheel with the correct offset in the first place. My message here is agreement with Skod to try to avoid using thick spacers, but if you must, do as much as you can to avoid the problems Skod pointed out. And be extra careful about torquing the studs before running. Use a torque wrench for sure. Torque to the spec for your wheel studs. Don Wollesen ---------------------------------------------------------------------- link If that wasnt ennough to steer you away.....and you're still eager to buy them, then please read on... As far as I know there are two types of spacers, the hub centric and the plain normal spacer. You should not buy this..EVER. ![]() You can buy this... ![]() When you install the hub centric spacer you can see that the protruding ring will give support and transfers most of the load into the wheel. ![]() The one without it wont be able to and thus all of the load are now acting perpendicular to the bolts...and thats bad because the bolts werent built to support such a massive load.Over time stress&strain will slowly creep in and the bolts will fail, imagine this when you're doing 100km/hr. DONT EVER DO THIS IF YOU VALUE UR LIFE. ![]() .....and heres a pic for entertaiment ![]() ![]() This post has been edited by lubu: Aug 13, 2008 - 7:52 AM -------------------- ![]() 98% completion --- aaRon |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
very good read....thanks for that but i am still unclear on the first 2 pictures of the spacers...what is the difference between them?...they both look identical yet one is sugested and another is not
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
One has the wheel/hub centering peice [basically a boss around the center hole] and the other does not.
![]() This post has been edited by DEATH: Aug 13, 2008 - 8:29 AM -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
![]() Enthusiast ![]() ![]() ![]() Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) ![]() |
The second pic has a protruding ring in the center and the first one doesn't have it.
-------------------- -Derick
![]() "In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
o00o ok...i got ya
All H&R spacers are hub centric.
I've had 1/2 spacers for about a year now, and never had a problem. Just dont buy cheap crap. This post has been edited by lagos: Aug 13, 2008 - 11:09 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
they forgot to mention how spacers screw up the rest of the suspension as well
In case someones wondering how thick those spacers above are...
they are 30cm each... ![]() -------------------- ![]() 98% completion --- aaRon |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
i took mines off. there was no good sturdy contact on wheel to hub
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) ![]() |
i have H&R hub-cent 15mm's coming in the mail in the fall. since i my car will see the track more and more....its too much of a risk. i might run them for the off season, but i havent decided yet.
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
i have H&R hub-cent 15mm's coming in the mail in the fall. since i my car will see the track more and more....its too much of a risk. i might run them for the off season, but i havent decided yet. 15m come with longer studs. Those are the ones I have. They sit perfectly on the hub and are hub centric. -------------------- 15PSI - 30MPG - Megasquirt Tuned
yeah, but i would rather not use them when i auto-x
I might be interested in them but gotta pay a few things first. I'd only use them when the car had it's nice shoes on LOL. For racing I'll be using the GTS rims I'm buying and will remove the spacers at the same time. Hit me up via PM when you get them and if I've paid off the other stuff I'm getting by then I'll buy them off you [price dependant of course]
will do
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) ![]() |
That's the reason why I haven't gotten spacers, even though I need them BAD with my Enkeis. They're sunk inside the wheel well. I would love them to be almost flush with the fenders, like on Mini Coopers.
Lo-Fi Version | Time is now: February 13th, 2025 - 1:23 PM |
