Enthusiast ![]() Joined Mar 18, '08 From Staten Island, NY Currently Offline Reputation: 0 (0%) ![]() |
I'm looking to replace the underdrive pulley in my 1996 AT200. I have quite a massive sound system though, so I don't want anything that limits the power to my alternator. If anything, the same size as stock as long as it's lighter. Any ideas?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) ![]() |
None... "Underdrive" means to "underdrive"... which means smaller pulley.
-------------------- "It's ok to be naked girl... I'm an artist!"
Okay, let me rephrase. I'm looking for something the same size with a lighter rotational mass.
![]() Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) ![]() |
Okay, let me rephrase. I'm looking for something the same size with a lighter rotational mass. Hmmm....Less weights = less stress on the motor? This is what you are trying to accomplish without changing the actual size of the pulley? I doubt you will even find anything other than OEM (not saying you won't, just saying good luck). -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
Nengun has the C-ONE pulley for the 3sge/3sgte, but i'm not sure if it will work on a 5s.. but it definitely won't work on a 7a.
....i just noticed it's only 640g! that's pretty damn light... -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Get a light flywheel. Reducing pulley weight is minuscule compared to the flywheel, where you can shave 1/2 the weight.
Get a light flywheel. Reducing pulley weight is minuscule compared to the flywheel, where you can shave 1/2 the weight. X2 I'd go with a lighter flywheel -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) ![]() |
APC makes an underdrive pulley made out of CNC machined aluminum for the 7AFE motor. I have one on my car and it is MUCH lighter than the stock one...it took me a while to find the right belt sizes because their belt guide is incorrect, now if you do have a big I.C.E system then you are right you may not want to underdrive your alternator, unless you replace it with a more powerful one in order to make up for the loss.
BTW i think if you are looking for power and engine response increases, this mod is well worth it. Good luck with the decisions. -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
APC makes an underdrive pulley made out of CNC machined aluminum for the 7AFE motor. I have one on my car and it is MUCH lighter than the stock one...it took me a while to find the right belt sizes because their belt guide is incorrect, now if you do have a big I.C.E system then you are right you may not want to underdrive your alternator, unless you replace it with a more powerful one in order to make up for the loss. BTW i think if you are looking for power and engine response increases, this mod is well worth it. Good luck with the decisions. I already do plan on swapping out the flywheel as well. If I can't find anything I guess I'll get them made custom. My sound system is pushing a little over 3000 watts and my headlights already dim when it's bassing. |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) ![]() |
APC makes an underdrive pulley made out of CNC machined aluminum for the 7AFE motor. I have one on my car and it is MUCH lighter than the stock one...it took me a while to find the right belt sizes because their belt guide is incorrect, now if you do have a big I.C.E system then you are right you may not want to underdrive your alternator, unless you replace it with a more powerful one in order to make up for the loss. BTW i think if you are looking for power and engine response increases, this mod is well worth it. Good luck with the decisions. I already do plan on swapping out the flywheel as well. If I can't find anything I guess I'll get them made custom. My sound system is pushing a little over 3000 watts and my headlights already dim when it's bassing. ever think about getting a ground kit to help you electircal system, but on topic lighter flywheel and and look into the mentioned puller above -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) ![]() |
Or you can get a few Caps. 3 farats should be fine....then you should be ok...i was thinking about getting this but it is like 125 dollars or so
http://www.aspracing.com/import.htm#toyota This post has been edited by Daftboy: Sep 25, 2008 - 5:20 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) ![]() |
negitive guys...fensport makes a oem size lightened alt, crank pulley
and oversized water pump pulley http://www.fensport.co.uk/products.htm Its hella expensive but..Where else are you gonna find them. And i've had the lightened flywheel..i hated it..Just my 0.2 cents though * go to the parts section..then to the st200 section..half way down the page. =] -------------------- ![]() |
Enthusiast ![]() ![]() Joined Dec 22, '04 From O'fallon, MO Currently Offline Reputation: 1 (100%) ![]() |
negitive guys...fensport makes a oem size lightened alt, crank pulley and oversized water pump pulley http://www.fensport.co.uk/products.htm Its hella expensive but..Where else are you gonna find them. And i've had the lightened flywheel..i hated it..Just my 0.2 cents though * go to the parts section..then to the st200 section..half way down the page. =] i bought an unorthodox racing underdrive pulley years ago, still havent even put it on haha need to get to that sometime..dont know how it compares to the stock size tho, just thought i'd throw it out there in case u wanted to look it up |
Enthusiast Joined Sep 13, '08 From Australia Currently Offline Reputation: 0 (0%) ![]() |
I wonder if the celica alternator is really any good anyway... I mean, it looks kinda small. There is a different one installed in the camry I think. I think I'd like to look at bigger and more reliable alternatives. What else is possible? What about an alternator pully with extra cooling blades on the other side? Or what is the largest alternator available for this?
This post has been edited by 3SGTE-auto: Oct 12, 2008 - 8:16 AM |
Lo-Fi Version | Time is now: April 21st, 2025 - 7:35 AM |
