Keep Blowin Out A/C Fuse!!! |
Oct 6, 2008 - 9:13 PM |
Enthusiast Joined Apr 24, '04 From S. Cali Currently Offline Reputation: 0 (0%) |
So basically my problem is that every time i try to turn my a/c, i blow out the 10A fuse in the fuse box, the one under the steering wheel.
Im guessing its a problem with the switch, but everytime it tries to engage the clutch on the compressor it blows out the whole climate control panel. I thought i had a short somewhere in the cabin, but i couldn't find anything. Im all out of ideas...has anyone had this problem or know of any possible solutions?? Thanks This post has been edited by Davesceli: Oct 7, 2008 - 12:48 AM |
Oct 7, 2008 - 12:53 AM |
anybody...
Oct 7, 2008 - 8:40 AM |
Enthusiast Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
Does the heat work? Fan blowing air?
If those work normally until you press the a/c button then odds are it's the clutch on the compressor. |
Oct 7, 2008 - 10:42 AM |
yea all that works...it only does it when i switch on the a/c. Is there anyway to check the clutch?
This post has been edited by Davesceli: Oct 7, 2008 - 10:54 AM |
Oct 7, 2008 - 1:59 PM |
Enthusiast Joined Jun 16, '08 From va beach Currently Offline Reputation: 2 (100%) |
I'm having the same problem. I had my A/C system checked and discovered that my compressor was the problem. When its seized, the compressor draws to much amps and blows the fuse. So, that would be the first thing i would check. I still have not fixed mine and won't until next summer. The compressor cost $200-$500 and the expansion valve needs to be changed with it as well which is only $25.00. BUT the expansion valve is behind the dash which means TONS OF LABOR!!!!
Casey -------------------- |
Oct 7, 2008 - 4:14 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
i was looking on my car for the ac fuse but cant find it, what is it labeled as? CDS ?
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Jun 24, 2012 - 2:16 AM |
Enthusiast Joined Jun 24, '12 From Texas Currently Offline Reputation: 0 (0%) |
So basically my problem is that every time i try to turn my a/c, i blow out the 10A fuse in the fuse box, the one under the steering wheel. Im guessing its a problem with the switch, but everytime it tries to engage the clutch on the compressor it blows out the whole climate control panel. I thought i had a short somewhere in the cabin, but i couldn't find anything. Im all out of ideas...has anyone had this problem or know of any possible solutions?? Thanks My Celica is doing exactly what you described but how can I tell if the compressor is bad? Spent the entire day and half the night in the TX heat trying to figure this out! Any help would be greatly appreciated. |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:31 AM |
