> Energy Suspension sway bar bushings
post Oct 23, 2008 - 5:34 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I want to get new rear sway bar bushings to get rid of any noise the old ones might be making, and I say that Energy Suspension makes universal bushings based on the size of the bar. I measured the rear sway bar with a dial caliper and it's 16mm.
http://www.energysuspensionparts.com/Unive...ar-Bushings.asp
I believe we have non-greaseable bushings, so it should be these:
http://www.energysuspensionparts.com/prodd...asp?prod=9.5120
If someone could confirm dimensions of the brackets that would be awesome. This would be a nice and cheap little upgrade. I would do my fronts as well if someone knew the size of it so I can confirm which set to buy (they have an A and a B).
This post has been edited by GotToyota: Oct 23, 2008 - 9:14 PM
post Oct 23, 2008 - 5:39 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I thought it was determined that the OEM Toyota bushings were inexpensive and just as good?
post Oct 23, 2008 - 8:09 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (GriffGirl @ Oct 23, 2008 - 5:39 PM) *
When was this said?
At $16 for a pair of bushings it's certainly worth a shot. I would just like dimensions of the front and rear bushing brackets.
-Matt
post Oct 23, 2008 - 8:23 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Maybe it's just my computer, but the links aren't working for me.
What kind of measurements on the brackets do you need? I just replaced my sway bars today so I have the factory bushings and brackets sitting around to get measurements from.
post Oct 23, 2008 - 9:13 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (MaskedMan @ Oct 23, 2008 - 8:23 PM) *
I fixed the links.
Look at the first link under non-greaseable bushings, I just need those bracket measurements compared to the factory ones.
-Matt
This post has been edited by GotToyota: Oct 23, 2008 - 9:13 PM
post Oct 26, 2008 - 11:15 AM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Anyone?
Lo-Fi Version Time is now: December 3rd, 2024 - 3:22 PM
