> Front strut mount bearings
post Oct 23, 2008 - 10:02 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
I was wondering if the front strut mount bearings could be purchased alone without buying new strut top mounts? If I do need to purchase new strut top mounts, where would be a good place to buy them with the bearings included?
post Oct 23, 2008 - 10:18 PM
pipes
Joined Apr 23, '08
From boston MA
From the toyota dealer
post Oct 23, 2008 - 10:41 PM
azian_advanced
Joined Apr 18, '05
From Calgary
there are aftermarket (oem equivalent) ones around.. i dunno if you'd want to stick with oem mounts with an upgraded suspension...
or why not look for used ones? i think i have a few good sets (front and back) laying around...
post Oct 23, 2008 - 11:05 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE (azian_advanced @ Oct 23, 2008 - 8:41 PM) *
What's wrong with the OEM mounts for upgraded suspension? The only aftermarket ones I've seen that would be "better" than the OEM mounts would be the Cusco top mounts. I mainly need the bearing only, and figured that I might as well buy it new since it's a wearable part. If you do have a used one sitting around for sale, then that would work too though I suppose. I only need 1.
post Oct 24, 2008 - 6:54 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
I would expect you will probably need the whole mount -- the rubber portions tend to take the biggest beating over time, even in the California environment (actually, the heat might accelerate such deterioration).
1sttoyotaparts.com is a good source for reasonably-priced Toyota parts. The most common aftermarket version are KYB mounts, which are essentially the same as the OEM design-wise. Rockauto.com offers good prices on replacement parts.
As an aside, if you're redoing your suspension, make sure to also replace the spring seat insulators. Those can only be purchased from Toyota.
post Nov 1, 2008 - 10:31 PM
Badkarma
Joined Apr 23, '06
From Rochester, NY
well, I work at napa auto parts. That's where I bought mine. We have mount plates with the bearings, and we have them without. You can also buy the bearings alone. Anyway, mine work fine. I plan on getting KYB struts next but haven't had any problems with the mounts or bearig with the oem struts on there now.
Erich
post Nov 1, 2008 - 11:57 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
Cool thanks for the replies. I actually just replaced the bearing. It was like $30 at work for 1. Much better now smile.gif.
Lo-Fi Version Time is now: January 9th, 2025 - 10:35 PM
