> Round 2 Checklist, am i missing something?
post Dec 30, 2008 - 7:23 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
hey guys, was trying to get my thoughts together for when i get the NT2 back. I believe ive got the necessities out of the way, and i will list what i have, please feel free to add anything i may need later or forgotten.
i plan on dyno tuning it very soon after reciveing it so i may consider pushing the dyno date back if i add water/meth soon enough.
I have:
4th gen 3sgte
Emanage blue EMS
Areomotive FPR
Koyo racing radiator
550cc injectors (stock should be enough?)
AIR/garett t3/t4 turbo
tial 38 wastegate
3inch exhaust from turbo back (mandrel bent)
turbo xs manual boost controller
turbo xs RFL BOV frown.gif RICE?!
Appropriate gauges...boost,oil temp, AEM wideband
stage 2 clutch (s54 tranny)
power goals: 320-350 (i know i know, i need a mr2 tranny) wink.gif
whp before swap:266/255tq@ 15psi on ct20b (stock boost level)
hopefully will be boosting 15-18 lbs w/ new turbo setup hopefully the intake manifold will hold up (crack repaired) and hopefully i shouldnt have any boost issues with the w/g placement
tips? suggestions?
post Dec 30, 2008 - 7:41 PM
get the WI asap.
its good stuff.
just FYI, the emanage is a piggyback, not EMS.
the s54 needs to go. with that kind of goal, you really NEED the extra gear the E153 provides.
and make it LSD while your at it.
after driving both with and without it, i can definetly say its the way to go.
what are the details on the turbo?
post Jan 3, 2009 - 12:29 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
its a 50 trim, non ball bearing.
i forgot to say that i will later add a catch can, i am still trying to decide on one i like. i want one that is baffled with a clear sight, but what is the efficiency difference between recirculating and just venting it? i also noticed in a guide i was looking at that the ones that were not baffeled were recirc. and ones that were baffeled were vented. why? excuse my ignorance.
i am leaning toward the cusco 600ml.
and i totally agree manny, the s54 gotta go! wish i had the extra $ earlier to grab an mr2 tranny frown.gif
post Jan 13, 2009 - 12:32 PM
Jaws4God
Joined Mar 27, '04
post Jan 15, 2009 - 12:55 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (Jaws4God @ Jan 13, 2009 - 1:32 PM) *
lol! i got ya jaws, im working on my latest invention! the duplicator! lol
little dissapointed i didnt get any input besides manny kindasad.gif was curious what others would have on their checklist
This post has been edited by easternpiro1: Jan 15, 2009 - 12:56 AM
post Jan 27, 2009 - 10:33 PM
Jaws4God
Joined Mar 27, '04
hehe thanks bud.. you guys are just keeping me on my toes cuz I don't want to copy either you or nick frown.gif
post Jan 28, 2009 - 12:41 AM
JDM_Factory
Joined Mar 27, '08
From Fort Worth, TX
instead of getting the mr2 e153, get the solara or camry e153 tranny. They're not hard to find.
post Jan 28, 2009 - 1:27 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (JDM_Factory @ Jan 28, 2009 - 1:41 AM) *
or a Lexus ES
they are easy to find, but most of them are non LSD, so if you want a LSD tranny, better look for MR2 ( $ )
post Jan 28, 2009 - 9:20 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Except that the LSD in the MR2 tranny is designed for RWD use, not really a good idea. Get a Camry/Solara E153 and a Quaife, and be done with it smile.gif
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 28, 2009 - 9:58 AM
_Jim_
Joined Sep 22, '08
From Bergenfield
QUOTE (Dr_Tweak @ Jan 28, 2009 - 9:20 AM) *
-Doc
WTF does that mean? The MR2 LSD tranny is a great choice, I am currently running it and havent had the slightest issue....Do you think that because the MR2 is "RWD" that it would make a difference? If that is the case then I am sorry but you are misinformed. Its a mid engine car, so it doesnt have drive shafts, the axles go directly into the Tranny just like a FWD setup.
And why would you suggest buying a NON-LSD to install an LSD into, when you can just buy an LSD to start with? That doesn't make sense. A NON-LSD will run you about 400$ plus 1200$ for the quaife diff you suggested (http://www.nolimitmotorsport.com/prod/QDF17E) plus Axles 200, plus having the cost of having the new LSD installed (if you dont do it yourself) Totaling over 1600, that does NOT included the cost of swapping out the Differential to the New LSD.
Or you can just buy an LSD tranny with axles for around 1000-1400 and be DONE with it.
330whp 309ft/lbs @ 21 PSI
post Jan 28, 2009 - 10:38 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE (_Jim_ @ Jan 28, 2009 - 9:58 AM) *
-Doc
In a FWD, it's important to use a gear-type LSD, also called a Helical Gear LSD or an ATB (automatic torque biasing) differential, because the wheels are you applying the power to are also the wheels that steer the car. In a RWD, this isn't a concern and so LSDs for RWD vehicle are usually more of a "locker" type or clutch type, which if used in a FWD car, could cause a dangerous condition in certain situations, such as corning in slippery conditions. I'm quite sure that the LSD in the MR2 transmission is of this type (since there is a visible "diff pin" in the axle hole), although I suppose I could be wrong. I've had some conversations with people using the MR2 LSD in FWD use and it giving them a lot of problems.
It's very important to understand that there are MANY different types of differentials and they all work differently, and are typically made for different uses. The Quaife LSD is specifically designed to work in FWD use as well as RWD, as a torque biasing differential it does not "lock" but smoothly transfers torque (torque biasing) from one wheel to the other, up to over 90% to whichever wheel has more traction. Using a Quaife is DEFINITELY more expensive. Doing things right the first time usually is smile.gif (Plus, the Quaife has a lifetime warranty biggrin.gif )
-Doc
*edit*
This conversation inspired me to sit down and do some research on what type the OEM LSD in the MR2 transmission is. It seems that there's no clear answer, most of the gen 2 engines have transmissions with a viscous coupling LSD, but it seems that the gen 3 engines often, but not always, come with an aftermarket clutch-type LSD. This may explain the variation in the results people are getting when using an MR2 LSD in a FWD Celica: the viscous coupling LSD will probably work just fine (although not nearly as effectively as a Quaife), whereas the clutch-type is going to give potential problems in FWD daily-driven use. With all the questions and confusion, it makes a lot of sense to spend a couple hundred bucks more to put a Quaife into a transmission already set up for FWD and be done with it. Then you KNOW that you have the best LSD you can get smile.gif
-Doc
This post has been edited by Dr_Tweak: Jan 28, 2009 - 11:20 AM
post Jan 28, 2009 - 2:38 PM
well here is something to think about. the selector shaft on the MR2 is on the wrong side. it might be better to get an all-trac tranny and convert it to FWD (not hard to do) i dont know what side the Camry/solara selector shaft is on.
its a PITA to change sides of the selector shaft.
post Jan 28, 2009 - 3:39 PM
Dr_Tweak
Joined Mar 31, '04
The Camry/Solara selectors are on the correct side for FWD use.
-Doc
post Jan 28, 2009 - 4:42 PM
trdproven
Joined Aug 2, '05
From Guam
good info.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 30, 2009 - 2:53 AM
tweak, who are these people who have had issues with the mr2 lsd?
again, im strictly talking mr2 lsd trannys in celicas.
smaay switching the selector arm takes all of 5 minutes.
much easier than converting an AWD tranny.
post Jan 30, 2009 - 10:00 AM
Dr_Tweak
Joined Mar 31, '04
I was hoping he would post up, I can't remember for sure and I get so many PMs that I have to empty my inbox a couple times a week LOL. GT4Wannabe maybe? It was someone who usually posts quite a bit in the technical sections....
post Jan 30, 2009 - 10:09 AM
QUOTE (Dr_Tweak @ Jan 30, 2009 - 10:00 AM) *
He probably got a none lsd trans when he thought he paid for an lsd one.
post Jan 30, 2009 - 12:56 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
Alright Tweak I did some searching, and couldn't find any posts from the VERY few people who are running an LSD, having "trouble" with the LSD trans. No offense, but have you ever driven a Celica with an E153, let alone a Celica with an E153 with LSD? I don't mean that in a negative manor, I just dont want to spread Misinformation on 6GC due to one bad apple. So if you have PERSONALLY had a bad experience with an Mr2 LSD transmission then I would like to hear about it. There are to many variables that would have to be looked at, to make such a statement based upon a PM through a second hand source. For example, The condition of the Trans itself, what ACTUAL Diff was in there (because if an aftermarket 2-way type LSD that was installed in there, that would account for a miserable ride for either car MR2/Celica), what other parts does this person have surrounding the trans (in example, is this person using proper mounts, shifter cables, spacers if necessary, etc), and what problems he was actually encountering.
I have OWNED and EXPERIENCED all 3 setups....S54/E153/and LSD E153. And I can tell you from EXPERIENCE that a well done, properly setup E153 swap (LSD or NON-LSD) will drive exactly the same way a Stock S54 will, but with the advantage of longer gears. There are absolutely NO differences between the S54 and the NON LSD E153 in drive-ability. The only difference when using an LSD from an MR2 is better traction wink.gif. The only difference you "feel" is when trying to accelerate hard through a turn, you feel the car want to "straighten out." For a better explanation, when accelerating hard through a tight right hand turn, you FEEL the car want to actually drive to the right. And the opposite goes for when you are accelerating hard through a tight left turn, you FEEL the car want to drive more to the left. And this is as far as it goes. Its just a feeling, nothing really more than that....That is the best way to describe it, this is nothing uncomfortable, not hard to control at all, and certainly NOT dangerous.
So again, READING things over the internet through a wide array of different possibility that may not be covered....sometimes doesn't cut it. Where as having REAL LIFE EXPERIENCES with your own properly done setup can give you a more realistic opinion/knowledge of said topic. Lets not "ruin" the advantages of being able to buy an E153 with factory LSD due to some VERY UNCLEAR information. I would love for you to post up the PM/the post/or the link to where you have read this, because it goes against EVERYTHING I have READ, and EXPERIENCED so far....I would like to be able to see where the problem lies, for future reference and for my own perosnal knowledge/learning
post Jan 30, 2009 - 2:52 PM
not to really be an ass or anything, but to me, it just sounds like somthing a guy would say when trying to upsell his services.
which i really cant blame you for, its how you make money. i just dont want this community to be misinformed because of it.
post Jan 30, 2009 - 3:20 PM
This reminds me of the times people who had no first hand experience would post that the s54 cant possibly hold the power of a stock 3sgte swap. Then they would point to some one guy who though his trans blew, when in fact he later found out it was only a clutch issue.
You cant just go by the second hand experiences of one person.
Lo-Fi Version Time is now: November 24th, 2024 - 9:39 AM
