> rubbing issues on my 6gc.., need advice
post Jan 2, 2009 - 12:45 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
hey guys, i've got 18" x 7.5" 5-spoke TRD wheels that are currently front rubbing on my 6gc..
the wheels have a +42 offset on 225/40/18 pirelli pzero tires.
so what could be the problem???
Stay Conscious and Aware -
Do not decide who to trust, decide which ideas to trust.
post Jan 2, 2009 - 1:02 PM
95st-celica
Joined Mar 29, '07
From Philly
is it droped? coilovers? springs?
1988 Dodge Aries K (sold)
post Jan 2, 2009 - 1:26 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
your offset???
Akirad1
Joined Jun 2, '08
From Fort Worth, Texas
roll your fenders that might fix it
post Jan 2, 2009 - 4:36 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
roll my fenders? how would i properly execute that? i was wonderin if a 5mm or 7mm wheel spacer would fix the problem.. if so, then which would be best fit? 5mm or 7mm? let me know.
post Jan 2, 2009 - 5:49 PM
Akirad1
Joined Jun 2, '08
here you go
http://www.youtube.com/watch?v=DDTK9IjKIYU...feature=related
post Jan 2, 2009 - 10:22 PM
jdg371
Joined Jun 14, '05
rolling your fenders for the first time might not be the best idea, paint can easily crack if you do not execute it properly. What kind of suspension are you running? Rolling the fenders can be done with a tool that can be ordered from Tirerack (expensive) or a couple lightweight hammers, or the very old school way of heating and baseball bat (louisville slugger)
post Jan 3, 2009 - 2:41 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
stock suspensions so far.. have trd springs in the garage that are still in package.. might be getting 10mm spacers now after having read the wheel offset page to achieve the flush look and fix the problem. yay or nay??
post Jan 4, 2009 - 3:31 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (MacgibaS2 @ Jan 3, 2009 - 4:41 PM) *
Before you buy spacers first figure out where it is rubbing.
Outside by the fender?
Inside by the Suspension?
If it rubs outside and you buy spacers it will make it worse. If it rubs inside and you buy spacers it will make it better.
post Jan 4, 2009 - 4:21 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
QUOTE (Harold_Fastwaker @ Jan 4, 2009 - 4:31 PM) *
I believe it has been rubbing from the inside due to the +42 offset and stock suspension setup.. so spacers should fix the problem right?
post Jan 4, 2009 - 7:18 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (MacgibaS2 @ Jan 4, 2009 - 5:21 PM) *
yes.
post Jan 4, 2009 - 8:47 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
Would an adapter be required?? +42 offset with 8mm spacers= +34?? i've gotta know for sure before purchase..
QUOTE (Harold_Fastwaker @ Jan 4, 2009 - 7:18 PM) *
yes.
post Jan 5, 2009 - 12:24 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
I believe any spacer 10mm and under is just fine on stock studs.
post Jan 5, 2009 - 7:16 AM
trdproven
Joined Aug 2, '05
From Guam
sounds more like it is rubbing on the suspension side than the fender based on the specs provided. It is not wide enough nor low enough offset to rub on the fender.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 5, 2009 - 8:03 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (MacgibaS2 @ Jan 2, 2009 - 6:45 PM) *
I believe you have wrote enough for roght answer...
1. roll fender is nonsense. You said you have problem with front. Rolling fender is good only for rear...
2. is your trouble wheel arch or fender?
a) if it's wheel arch -> spacer will do the job
however... according to numbers you have posted... let's have some math:
I have 205/50/16 on 16'' x 7.5'' offset +35 - no rubbing even with lowered front for 25mm
you have 225/40/18 on 18'' x 7.5'' offset +45 and you car is not lowered...
so... your rim is the same width and for 7mm closer to wheel arch (7mm more far from fender) but your wheel with that size of tire is bigger (diameter is for 26mm bigger and width is also plus 20mm). So... in my opinion your wheel is for 17mm closer to wheel arch and for 3mm closer to fender than my is. That means you more probably rub wheel arch that fender.
you have only two ways to go:
1.: buy spacers 5mm or better 10mm -> to be far from wheel arch for 10mm (if you have chance for custom size of spacer I would use 7mm spacer cuz there is still the chance you may start rubbing with fender not the arch this time)
2.: buy 225/35/18 tires -> to have the same diameter of wheel (only for 4mm bigger diameter than my ones!!!)
post Jan 5, 2009 - 5:11 PM
MacgibaS2
Joined Dec 14, '08
From La La Land..
QUOTE (malpaso @ Jan 5, 2009 - 8:03 AM) *
thanks for all the replies guys.. much appreciated! i'll be getting custom 7 or 8mm spacers then for all 4 wheels or just for the front? by summer, i'll also incorporate 215-35-18 tires for the front.
post Feb 3, 2009 - 5:21 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
so i bought some 16" rims and 225/50r16 toyo tires a month ago. So each time i make a u turn it rubs a little on the inside of the time. So if im making a left u-turn then only the front left tire will rub. The same goes for the right front tire when i making a right u-turn.
This is where it rubs at on both sides.
What do you guys think, like my rims???
This post has been edited by BonzaiCelica: Feb 3, 2009 - 5:26 PM
post Feb 4, 2009 - 5:38 AM
malpaso
Joined Feb 3, '06
QUOTE (BonzaiCelica @ Feb 3, 2009 - 11:21 PM) *
your tire is to big mate... you should have profile 45 with that wide tire like 225 is at 16inch rim...
post Feb 5, 2009 - 11:33 PM
BonzaiCelica
Joined Apr 24, '08
really hmm well alot of members have been saying they have 225/45r17 which is similar in size as the tire that i have and they have had no problem.. but i know what you mean ill get some 45 profile tires next time thanks!
This post has been edited by BonzaiCelica: Feb 6, 2009 - 12:29 AM
Lo-Fi Version Time is now: November 27th, 2024 - 2:28 PM
