> Where is the airbag fuse?
post Jan 4, 2009 - 2:18 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
I have looked in all the relay/fuse boxes in the engine bay, but none are labelled airbag?
post Jan 4, 2009 - 4:54 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Ignition / radio/cig lighter fuses. Here is what it actually says "WHEN THE IGNITION SW IS TURNED TO ACC OR ON, CURRENT FROM THE CIG & RAD FUSE FLOWS TO TERMINAL 14 OF THE
CENTER AIRBAG SENSOR ASSEMBLY. ONLY WHEN THE IGNITION SW IS ON DOES, CURRENT FROM THE IGN FUSE FLOWS TO
TERMINAL 13" You trying to disable the airbags or something? BTW, if there was an airbag fuse itd be labled SRS....I know there is an SRS warning fuse.
post Jan 4, 2009 - 6:11 PM
Promasta
Joined Oct 2, '07
if you want to know, a shop screwed my airbag sensors and will not fix them for me, and i dont have $800 for new ones
so since the airbags don't work anyways, i figure i might as well take the fuse out so i don't get the warning light on the gauge cluster
i will look for a fuse labelled SRS, thank you
post Jan 4, 2009 - 8:02 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Wow, sorry to hear that. SUcks when people break things and dont want to cover their mistake for you. Yeah, just look for the SRS warning fuse. Cant say if it'll affect the airbags themselves (from working) with the case with your sensors.
post Jan 5, 2009 - 12:04 AM
SRS fuse in the engine bay, 7.5 amp. Pull the fuse and the light will not come on.
Lo-Fi Version Time is now: February 23rd, 2025 - 10:46 AM
