![]() Enthusiast ![]() Joined Jun 9, '06 From Vero Beach Fl. Currently Offline Reputation: 15 (100%) ![]() |
I have a '98 GT. After having installed a new head unit and disconnecting the battery, the alarm went off when I tried to start the car. I disconnected the horn and played around with it for 10 minutes before I could get it to turn over and start. I have no idea what I did to get it to finally turn over. Can anyone explain the proper procedure to re-set the alarm after it has been triggered?
![]() Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) ![]() |
I believe you turn the key to "on" then "off" then "on" and maybe "off" one more time? It's something like that. It might even be three times.
Enthusiast ![]() ![]() ![]() Joined May 22, '08 From dallas texas Currently Offline Reputation: 11 (100%) ![]() |
do you have the toyota securikey deal? thats what i have and its a PITA when you reconnect battery, button has to be out turn key to on-not start- push button in, then start the car, then push button out sooooo annoying
do you have the toyota securikey deal? thats what i have and its a PITA when you reconnect battery, button has to be out turn key to on-not start- push button in, then start the car, then push button out sooooo annoying Thanks, that should be easy enough to remember. -------------------- ![]() |
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) ![]() |
I was wondering if that was a factory alarm or not. I've only had to disconnect my battery once. So i've only had to turn off my alarm once. its too much of a hassle to mess with actually turning it on.
-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
do you have the toyota securikey deal? thats what i have and its a PITA when you reconnect battery, button has to be out turn key to on-not start- push button in, then start the car, then push button out sooooo annoying THANKS!!! You are exactly right. I did a battery disconnect and reconnect to try your suggestion, and it worked. -------------------- ![]() |
ya check the other thread too-i had to do it many times cuz of a loose battery cable
my switch is right by fuse box on drivers side above hood latch-assuming thats the factory place? |
UPDATE: In case anyone has a similar problem, I had a young lady show me a much easier way to reset the factory anti theft alarm. The alarm on her Celica had gone off and discharged the battery. When we jump started her car, she showed me how to reset the alarm. All you have to do is place the key in the driver's side door lock and rotate from lock to unlock ten times. This resets the alarm if the battery is disconnected or goes dead.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
UPDATE: In case anyone has a similar problem, I had a young lady show me a much easier way to reset the factory anti theft alarm. The alarm on her Celica had gone off and discharged the battery. When we jump started her car, she showed me how to reset the alarm. All you have to do is place the key in the driver's side door lock and rotate from lock to unlock ten times. This resets the alarm if the battery is disconnected or goes dead. That's not gonna work for people like myself, who have a factory alarm but not power windows or locks ![]() Good tip for everyone else though! Thanks! -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) ![]() |
my factory alarm is getting old and going on and off on me. Right now it's dead I think.... I replaced the battery in it but it works whenever it wants to only. and it doesn't do much either. I think I'll just upgrade to aftermarket of somesort.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Lo-Fi Version | Time is now: February 21st, 2025 - 7:55 AM |
