my shocks move what should i do?, I just installed my new shock sleeves. |
Jan 21, 2009 - 3:49 PM |
Enthusiast Joined Dec 28, '08 From long beach, CA Currently Offline Reputation: 0 (0%) |
I just finished installing my suspension. After a few miles of driving on crazy bouncy roads my suspension started clunking!!! So what i installed was the sleeves by cutting the old cartrdiges out of the stock set up. Well i noticed there was some play so i stuffed it with some rubber. Im guessing after the rubber pieces came off the car started clunking. Has anyone had this problem? How can i make it so my suspension stays put?
KYB GR2's (back is compplete strut front is cartridge) cant find the link from koni atm ill post later |
Jan 21, 2009 - 7:07 PM |
Jan 21, 2009 - 7:26 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Huh? How did you cut the cartridges out of the old struts? I removed mine with a large vice grip holding the nut and turning the strut.
I notice that you will have play if you don't align the strut at the top to your mounting plate correctly. Do you have konis or GR-2? pictures plz. Im starting to get lost. |
Jan 21, 2009 - 7:47 PM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
didnt i tell you to let someone who experienced do this???
Jan 21, 2009 - 8:10 PM |
Lew why pay someone when i can do it? if anything i should have bought the complete strut. Either way its too late for that now. I know a few others have done there suspension this way and im hoping they can shed some light on how to fix it so i dont have to go buy the complete strut.
Jan 21, 2009 - 8:13 PM |
wheres the pic of the strut housing?
Jan 21, 2009 - 8:56 PM |
heres the housing its still in my car. I might weld the old piece i cut off to the strut assembly.
/fayl cant return them anymore they are scrapped like crazy now...sigh |
Jan 21, 2009 - 9:25 PM |
Enthusiast Joined Dec 5, '05 From Clemson, SC Currently Offline Reputation: 1 (100%) |
I'm kinda confused. Did you cut off the large nut on the top of the housing? If so, that's not good. The nut holds the cartridge inside the housing. A piece of rubber isn't going to hold it. I could be wrong though....
Jan 21, 2009 - 9:42 PM |
nah my car didnt have a nut on top. It appeared to be a enclosed strut.
Jan 21, 2009 - 11:14 PM |
you had sealed struts. were they even blown?? why would you weld a top back on? id say you have 2 options now...buy the whole strut or buy some non-sealed ones and use your inserts. better off buying the whole strut and reselling the inserts since they both cost the same
Enthusiast Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Well there's your problem... there is nothing holding the strut in place. If yours didn't have the nut it's not rebuildable. You need the whole strut assembly.
EDIT: Lew beat me to it. This post has been edited by WannabeGT4: Jan 21, 2009 - 11:15 PM -------------------- Project ST204.5 99.88946% complete... |
Jan 22, 2009 - 1:17 AM |
Kewl thanks for the help guys and i will be taking your advice for ONCE Lew LOL ill buy the complete strut.
the shocks: yea they were blown/destroyed, i had chipped metal floating inside the housing. This post has been edited by Salica: Jan 22, 2009 - 1:19 AM |
Jan 22, 2009 - 3:39 AM |
Enthusiast Joined Jan 10, '09 From hamilton new zealand Currently Offline Reputation: 0 (0%) |
I agree im a mechanic and have delt with these you need that nut to hold the actual shock inside the strut by memory you will need to get new strut housings for the shock all its din is bouncing inside whats left of the strut with no shock absorbtion at all
Lo-Fi Version | Time is now: November 28th, 2024 - 5:44 AM |
