Is there a how to for valve gasket 5sfe |
Jan 23, 2009 - 12:25 PM |
Enthusiast Joined Nov 5, '08 From Tampa, FL Currently Offline Reputation: 9 (100%) |
Was going to do a DIY on the valve gasket. and was needing specs, torque and where to apply rtv on a 5sfe
Jan 23, 2009 - 1:26 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Well the process is simple just remove the big nuts around the spark plug wells with a socket, I believe it's 30 or 31 mm I don't remember, it's the same size as the axle nuts. As for RTV you don't really need it since it's a rubber gasket, but if you apply it just use it on the corners and sharp bends, mostly just to keep it in place while you re-install the valve cover. The torque specs are pretty low, I don't remember them off the top of my head but they are something like 14-17 ft-lbs (please correct me if I am wrong, been a long time since I was a mechanic lol).
-------------------- 1999 Celica GT
Jan 23, 2009 - 1:38 PM |
Well the process is simple just remove the big nuts around the spark plug wells with a socket, I believe it's 30 or 31 mm I don't remember, it's the same size as the axle nuts. As for RTV you don't really need it since it's a rubber gasket, but if you apply it just use it on the corners and sharp bends, mostly just to keep it in place while you re-install the valve cover. The torque specs are pretty low, I don't remember them off the top of my head but they are something like 14-17 ft-lbs (please correct me if I am wrong, been a long time since I was a mechanic lol). I found it, it is 17 ft-lbs is there an order for tightening the four nuts? |
Jan 23, 2009 - 4:45 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
You DO need to apply the RTV. There are many threads about people not using it only to discover it leaks after installation.
Jan 24, 2009 - 5:21 PM |
Enthusiast Joined Aug 10, '08 From Raleigh, NC Currently Offline Reputation: 0 (0%) |
Reseal the half moons with FIPG when youre doing it. Apply FIPG at the seems of the half moon-to-head and in the corners of the end caps. It is a 30MM. socket and I always tighten the two middle nuts first then the outer ones, then repeat until all the nuts are tight.
Where did you guys find the torque spec. of 17ft/lbs.? -------------------- Trust me, I do this every day |
Jan 25, 2009 - 8:52 PM |
Reseal the half moons with FIPG when youre doing it. Apply FIPG at the seems of the half moon-to-head and in the corners of the end caps. It is a 30MM. socket and I always tighten the two middle nuts first then the outer ones, then repeat until all the nuts are tight. Where did you guys find the torque spec. of 17ft/lbs.? I got my hands on the full manual that was from Toyota it cover both the 1.8 vin A and 2.2 vin S |
Jan 26, 2009 - 10:12 AM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
i just did mine. FIPG was not needed but was recommended for use at the corners and the half moon section. ive been running it for a month and no leaks.
it is always handy to have some Toyota FIPG but if you cant get any at the time, its ok. oh and i might as well say it here, get FIPG instead of RTV. FIPG is a thicker substance and is more reliable. -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 26, 2009 - 10:16 AM |
Jan 27, 2009 - 12:31 AM |
Enthusiast Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
Hmmm i didnt use FIPG when i changed my gaskets and havent had a problem, and I do recommend also you tighten the centers first
Jan 27, 2009 - 12:42 AM |
Here I hope this helps a little, pics from when I did mine, the seal on the head is the old one
Feb 1, 2009 - 8:53 PM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
So i just replaced my valve cover gasket today and i found that the guy before me had applied RTV around the corners and half moons. when i took off the valve cover, all of that dried up RTV fell into the engine. it took me about an hour with tweesers to get it all out. i really don't recommend using that stuff..if anything use, FIPG. i didn't use any today simply because i didn't have any. but i'll just see how it works for now. i didn't use any on my last celi and i didnt have any problems with it.
Feb 3, 2009 - 8:04 PM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
You DO need to apply the RTV. There are many threads about people not using it only to discover it leaks after installation. Not trying to hi-jack a post but what is RTV and FIPG? -------------------- |
Feb 4, 2009 - 4:51 PM |
Room Temperature Vulcanizing (RTV) sealant (over the counter)
Formed-In-Place Gasket (FIPG) Liquid Sealant ( Toyota sells) |
Lo-Fi Version | Time is now: December 2nd, 2024 - 1:22 AM |
