> losing your afm for a map sensor
post Feb 4, 2009 - 7:29 PM
mk7celica
Joined Feb 2, '09
From new orleans La.
hello i am new to the site and have a 1994 gt coupe with a 3sgte swap that was just finished a few months ago, by scc.
i have added a mbc, full 3inch exhaust and down pipe, and some other odds and ends. but i have read about getting a map sensor and getting rid of you afm. is this to be done with a ems install or can you do it with factory ecu ect.?
what benifits will i get with a 1.8 bar sensor or what ever not sure what out there or what i need.
and 1 last thing i want a better turbo than my ct26. i have a fcd so the presure i want to run is 15-17PSI at the track only and 12-13 PSI max fornot aT TRACK. RIGHT NOW WITH MY STOCK CT26 AFTER 15 PSI IT SUCKS. SO I WAS LOOKING AT A CT27 FROM ATS BUT NOT SURE WHAT HP GAINS I WILL GET. ANY IDEAS ON WHAT TURBO TO GET THANKS
post Feb 4, 2009 - 8:20 PM
mk7celica
Joined Feb 2, '09
now i am looking at a 57 trim rebuild/upgrade from driftmotion for 600 bucks sound right? or is 57 trim to bigG?
post Feb 4, 2009 - 8:48 PM
dont bother with either turbo, look into a T3 super 60. awesome turbo! as for the MAP sensor, you can get the AEM EMS and convert to speed density which is how i run my All-Trac. or you can get the MAP ECU II that converts to a speed density. you will also have to add an air temp sensor
post Feb 4, 2009 - 8:54 PM
mk7celica
Joined Feb 2, '09
ok with a t3 super 60 what sthan cost and i guess with this turbui i will have to change my manifold? or get a t3 adaptor
post Feb 5, 2009 - 2:37 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
15 psi+ is serious business for a ct26, i hope for your sake its a steel wheel.
dont fnck around with higflows. Spend the money and get an aftermarket snail. If your only looking for a mild increase something like a disco potato from garrett would be an ideal starting point. You can get the adapter plate so you can use the stock manifold, they have internal gates and would still be as responsive as your stocker.
GRX133 Toyota Mark X 350s
post May 17, 2009 - 9:15 PM
mk7celica
Joined Feb 2, '09
QUOTE (Smaay @ Feb 4, 2009 - 8:48 PM) *
How do I go about getting rid of my afm for a map . Do I need a piggyback or ems? Or is there another way
post May 18, 2009 - 1:32 PM
alot of Supra guys love the MAP ECU II. you can get it here http://www.powerhouseracing.com/Templates/...&SearchYN=N
another option is the AEM FIC aempower.com
Lo-Fi Version Time is now: November 24th, 2024 - 9:27 AM
