> Replacing my alternator
post Feb 13, 2009 - 9:33 AM
mgpmatt
Joined May 16, '08
From PA
Ok so I just had one question before I do this. The book/the guy at autozone made it seem a little too easy.
I get that you undue the 3 bolts and take out the two connectors and all the basics, my main question is regarding the belt. How will I know if the belt is properly put back on/tight enough? Is there a special tool I'll need or can I do it myself?
Thanks,
Matthew
post Feb 13, 2009 - 9:35 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its pretty much a guess.
tighten the belt untill you can't push it more than 3/4-inch down in the center w/ moderate force.
if it squeeks, tighten the belt more
This post has been edited by stephen_lee: Feb 13, 2009 - 9:36 AM
post Feb 13, 2009 - 11:57 AM
azian_advanced
Joined Apr 18, '05
From Calgary
record the # of threads from the top of the screw that adjusts the tension of the belt.
This post has been edited by azian_advanced: Feb 13, 2009 - 11:57 AM
post Feb 13, 2009 - 7:05 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Yeah, there are some tools that you can use , a nippondenso or borroughs belt tension gauges. Or you can just use a straight edge and a ruler. pop the straight edge between two pulleys and use the ruler to measure the amount of deflection, shouldnt be more than 1/2 inch if the distance between the pulleys is 12-16 inches, or 1/4 inch if the distance is 7-11 inches. (you would need to measure from the center of the pulley).
This post has been edited by Spider77: Feb 13, 2009 - 7:08 PM
post Feb 24, 2009 - 4:09 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
wow measuring and all... way too tough... twist the belt between the alternator and pulley... if it turns more than 90* then you need to tighten it... if it squells... loosen it... that easy
This post has been edited by pittfirefighter: Feb 24, 2009 - 4:10 AM
Breaking Axles...
Lo-Fi Version Time is now: November 30th, 2024 - 2:04 AM
