> gauge cluster lights, just changed them to red...
post Oct 9, 2003 - 4:35 AM
Akuza
Joined May 2, '03
i just removed the gay green bulbs which was actually white but a green plastic cover wrapped around it and it was cheap
oh well i changed it to the red lights and they look sweet !!!!
im gonna post some pics up when i can get my friend's digicam
so just wait
post Oct 9, 2003 - 11:19 AM
Mynzeyes
From Franklin/Nashville, TN
full shot:
tach focus:
and here, you can see the difference between the euro/jdm tach and the usdm POS:
-John-
AIM==Mynzeyes
post Oct 9, 2003 - 11:57 AM
PlanetFuzz
Joined Mar 9, '03
From Knoxville,TN
that looks sweet! I need to do that
post Oct 9, 2003 - 1:58 PM
Akuza
Joined May 2, '03
ohhh 9000rpm....drool.....i want that
is it up for grabs ? i want i want !!!!!
post Oct 9, 2003 - 5:33 PM
I have a red gauge cluster as well, and I want a JDM tach too. That way I wouldn't need to get an external tach, because my fuel cutoff will be higher than 8,000 RPM.
post Oct 10, 2003 - 12:13 AM
Akuza
Joined May 2, '03
does it really work having one extra 1000 rpm ?
i thought the gauge would just max out at 8600 or somthing and it wouldnt even go to 9000
not sure on that someone correct me if im wrong
post Oct 10, 2003 - 12:24 AM
QUOTE (Akuza @ Oct 9, 2003 - 9:13 PM)
I'm not really sure what you're saying, but for my engine that's in my car now, my redline is at 7,800, 8,000, or 8,200 RPM. It's different based on the year of the AE101 ECU. Anyway, it'd be nice to be able to see exactly what RPM I'm at when I'm above 8,000 RPM, and that can't be done on the stock tach, as it only goes to 8,000 RPM. wink.gif
What I'll probably end up doing is just getting one of these. It's an awesome shift light that displays your exact engine RPM.
post Oct 10, 2003 - 11:56 AM
Akuza
Joined May 2, '03
those are nice but i dont like the design
post Oct 10, 2003 - 11:58 AM
QUOTE (Akuza @ Oct 10, 2003 - 8:56 AM)
The design of the JDM/Euro tach?
Also, did you use regular red type 194 bulbs, or did you use the type 194 LEDs?
post Oct 10, 2003 - 2:02 PM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
i used the type 194 blue bulbs, they have different color but you wouldnt know difference if you werent in the car eveyday with green. im going to get the red instead, it stands out more even tho my scheme interior is going to be blue, i might change it later on
post Oct 10, 2003 - 2:09 PM
DoodieHead
Joined Mar 31, '03
also, about the redline, for my st its 6200, that seems little low, is there a way to raise this, ie ecu or governor??
post Oct 10, 2003 - 2:29 PM
QUOTE (DoodieHead @ Oct 10, 2003 - 11:09 AM)
You could get an aftermarket ECU and raise your redline to something different, but the reason that the redline is at 6200 is so that you don't damage your engine by going over a higher RPM then what the engine is designed to handle. Reving higher than that on a stock engine will be bad for the engine.
post Oct 10, 2003 - 4:11 PM
edo17982
Joined Dec 21, '02
From Italy
Coomer, what u said is true, but the Celica ST after 1997 in Europe has a different ECU program that let the engine run till 7000 Rpms, so, since the engine is the same, 7k is safe for 7afe. Doogy can confirm this since he has that model of ECU wink.gif wink.gif
post Oct 10, 2003 - 5:03 PM
QUOTE (edo17982 @ Oct 10, 2003 - 1:11 PM)
Geez, not only do your STs get rear disks, but you also get 800 more RPM. Poor North America...
post Oct 10, 2003 - 6:24 PM
Akuza
Joined May 2, '03
ya poor st drivers
they dont get jack
go to the junkyard and look for some rear disk brakes
i got type 194 bulbs and i didnt like that design of that link you showed me
with the digital rpm gauge
post Oct 10, 2003 - 6:36 PM
QUOTE (Akuza @ Oct 10, 2003 - 3:24 PM)
ya poor st drivers
they dont get jack
Oh, you're talking about the SW Performance shift light. Now I get it. smile.gif
Also, I've been to a few junkyards and haven't found anything. I've also had dibs on three sets of rear disk brakes, but they all fell through because people sold the whole car or just backed out. frown.gif
post Oct 11, 2003 - 6:29 AM
Akuza
Joined May 2, '03
well im pretty sure theres some lying around just gotta keep an eye out for them
post Oct 11, 2003 - 8:00 PM
0Re0
Joined Nov 13, '02
From Hawaii
QUOTE (Mynzeyes @ Oct 9, 2003 - 9:19 AM)
full shot:
tach focus:
-John-
Yo John,
How did you install it?
post Oct 12, 2003 - 11:38 PM
0Re0
Joined Nov 13, '02
From Hawaii
This post has been edited by 0Re0: Oct 13, 2003 - 12:00 AM
post Oct 13, 2003 - 1:25 AM
QUOTE (0Re0 @ Oct 12, 2003 - 8:38 PM)
He told me that it's very easy once the gauge cluster is apart. It just goes right in. smile.gif
Lo-Fi Version Time is now: January 10th, 2025 - 6:49 PM
