stereo issues?, problems with the acc. |
Feb 18, 2009 - 9:10 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
i recently ran into a problem with my stereo (the deh-6900ub, by pioneer). first off i need to say that i wired it into the fuses. i did this over a year ago and suddenly it reset on me every time the car i turned off and the circuit is broken. i have the acc tapped into the 15a stop fuse, or maybe the ecu... i forget, but both of these are a circuit that remains unbroken when the car is turned off. my 12v yellow power wire is tapped into the cig/radio 15a fuse. the problem is that every time the car is turned off and the electrical circuit is broken all of my settings are lost. i even ran a new wire to connect the acc with. can anyone figure this issue out?
Feb 18, 2009 - 10:07 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
i recently ran into a problem with my stereo (the deh-6900ub, by pioneer). first off i need to say that i wired it into the fuses. i did this over a year ago and suddenly it reset on me every time the car i turned off and the circuit is broken. i have the acc tapped into the 15a stop fuse, or maybe the ecu... i forget, but both of these are a circuit that remains unbroken when the car is turned off. my 12v yellow power wire is tapped into the cig/radio 15a fuse. the problem is that every time the car is turned off and the electrical circuit is broken all of my settings are lost. i even ran a new wire to connect the acc with. can anyone figure this issue out? just curious, why didn't you just wire it to the 12v wire that plugs into the back of the CD player? -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Feb 18, 2009 - 10:09 PM |
not sure what you mean... but the acc has to be connected to something that is in constant circuit. the acc and the 12v are both connected to the battery... can you explain what you mean?... thanks
Feb 18, 2009 - 10:13 PM |
like the wiring harness coming from the car that you splice the cd player's harness into. why did you decide to use fuses? because one of the wires coming from the car is a 12v source that connects to your CD player.
Feb 18, 2009 - 10:15 PM |
i had the factory amp. i rewired the whole system.
Feb 18, 2009 - 11:00 PM |
Enthusiast Joined Nov 29, '04 Currently Offline Reputation: 5 (100%) |
Were you not aware that you could have just used the output harness of the amp? From what you are describing, your 12 volt constant wire is the problem, it's what retains your settings. If you have chopped up your radio wiring too much, just go to the main ignition harness for 12V constant and Accessory.
Edit: I just reread your post and you have your wires backwards. Yellow needs a constant power source. Red/Accessory needs a source that gets power when the key is turned to the accessory position. Again, if you have mutilated your OEM radio wiring, go to the main ignition harness. This post has been edited by gt_driFFter: Feb 18, 2009 - 11:00 PM |
Feb 18, 2009 - 11:05 PM |
thanks. i'll try it. they aren't chopped up... so i'll see if it works.
Feb 18, 2009 - 11:08 PM |
thanks. you were correct!
Feb 19, 2009 - 1:17 AM |
Glad I could help!
Lo-Fi Version | Time is now: January 10th, 2025 - 9:00 AM |
