> changing 5sfe timing belt, do i have to remove the crank pulley?
post Feb 18, 2009 - 9:11 PM
dark94gts
Joined Jan 6, '09
From edmonton, alberta
Is it a must to remove the crank pulley to get the timing belt off, or is it possible to change it with the pulley on? Its just a big deal to take it off for me, hard to find a puller and i dont have a good impact.
And should i change the idler pulley as well? The car has 240000km.
post Feb 18, 2009 - 9:49 PM
trdproven
Joined Aug 2, '05
From Guam
Gerald did a sticky on this go for it and read it.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 18, 2009 - 10:26 PM
dark94gts
Joined Jan 6, '09
yeah i read it but i was in high hopes someone had been able to do it without removing the pulley, but i guess not. looks like im in for a long days work.
post Feb 19, 2009 - 12:42 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Good luck you will need it. I had to go buy a 650lb ft torqe impact gun just BECAUSE I couldn't get the freakin Pulley off. It was so stubborn, 150lb was weak sauce, 250 didnt do squat, 350 was childs play and I nearly out of my mind bought a 1250lb torque hammer gun but the only thing stopping me was my Air comp. not supporting over 250 Psi, so I settled for the 650 which was the highest I could find that supported 150 psi range. mad.gif mad.gif mad.gif
post Feb 19, 2009 - 12:51 AM
dark94gts
Joined Jan 6, '09
frig, i have a 30$ 12 volt impact thats suppose to do 250lb ft torque, but its one that spins up for a couple seconds and then kicks in with one big bang, then spins up again and tries again. dont know if its up to the task, but im gonna find out:)
post Feb 19, 2009 - 1:04 AM
trdproven
Joined Aug 2, '05
From Guam
FWD suck for doing timing belt replacement on your spare time. RWD are much better access.
This post has been edited by trdproven: Feb 19, 2009 - 1:04 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 19, 2009 - 1:08 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
heat and a breaker bar is all that's needed to get out a stubborn crank bolt.
post Feb 19, 2009 - 1:12 AM
dark94gts
Joined Jan 6, '09
yeah im gonna try change it friday, i have from 9 to 4:30 to do it, then i have to pick up my wife from work and lets hope its working. oh and the high for friday is -8 celcius kindasad.gif
post Feb 19, 2009 - 12:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
good luck.
post Feb 19, 2009 - 1:48 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you're gonna work on it outside? yikes..
post Feb 19, 2009 - 6:59 PM
dark94gts
Joined Jan 6, '09
na im doing it inside a garage, but its not heat unfortunately:/ shouldnt be to bad though.
post Feb 20, 2009 - 2:33 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (dark94gts @ Feb 19, 2009 - 5:59 PM) *
post Feb 20, 2009 - 7:22 PM
dark94gts
Joined Jan 6, '09
well i spent most of today working on it, got the old belt off. there was a bad oil leak so i ordered a cam and crank seal, as well as valve cover gasket. i took the valve cover off though and there is black cooked oil caked everywhere in the head. its burnt go bad the oil is flaky. either someone never did oil changes, or it majorly overheated. either way its not good. ive never seen a engine so dirty from oil. but it does have 240000km on it. i had plans to go turbo with it this summer, but not sure if i will now. maybe do a swap
Lo-Fi Version Time is now: November 26th, 2024 - 10:34 PM
