> I HATE MY NEW CELICA
post Feb 20, 2009 - 10:46 PM
pirate4x4
Joined Jan 29, '09
From Mass.
So I got a 1994 celica 2.2. It has 180,000. I bought it needing a clutch. So i got the clutch and put it in. It was a pain in the ass. Finally after the clutch was said and done i take the car on the highway, engine got hot, and when i got home, i left it running and the radiator blew everywhere. THe power steering leaks, the drivers side door doesnt open, the battery is dead and the starter is no good. Dont know what im doing posting this, but im ready to throw this car in the trash. Not to mention i transferred registration today from a car that works fine to that piece, and now i have nothing to drive. I like this car, but hate it so much.
post Feb 20, 2009 - 11:03 PM
crwarrior
Joined Mar 1, '08
damn man...
i guess its not really a "NEW" celica is it lol
well i guess youll have to fix all these things so u can enjoy it =) when i bought mine it didnt even have tires or anything...so with patience ull end up loving it =)
post Feb 20, 2009 - 11:10 PM
hitek9
Joined Jan 15, '09
From Chicago
its a toyota, all this is not very hard or expensive to fix. where does the power steering leak from? where did the radiator break from? the door doesnt open from the inside or outside?? if you changed your own clutch than the rest should be a piece of cake
post Feb 20, 2009 - 11:12 PM
trdproven
Joined Aug 2, '05
From Guam
if you can replace clutch, u can easily replace those things, they won't cause you much and once you're done, this post will be the opposite.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 21, 2009 - 12:14 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
**Singing** Cheer up Charliiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiie (Taken from Willy Wonka and the Chocolate factory for you slow ones).
post Feb 21, 2009 - 12:16 AM
pirate4x4
Joined Jan 29, '09
From Mass.
thanks guys. I appreciate the advice. Hopefully ill be singing another tune by the end of the weekend
post Feb 21, 2009 - 12:56 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
Thankfully from the things you listed you only have about another $100 in repairs, probably less. Your overheating problems are probably because of a stuck thermostat. It sounds like the car has been sitting for a while and you might want to go over the hoses and belts to look for dryrot. And I would definately change the oil. Hope things get better.
This post has been edited by 95STHATCH: Feb 21, 2009 - 1:02 AM
post Feb 21, 2009 - 1:02 AM
crankyelbow
Joined Feb 11, '09
From south chi burbs
I have way more $ and time to put into mine to get it running solidly... but I know for sure after all is fixed this will be the favorite of all the cars I've owned... and certainly will be the fastest eventually smile.gif
Fix er up and enjoy, you bought the car for a reason (i assume you like it! smile.gif )
post Feb 21, 2009 - 4:45 AM
ej8ferio702
Joined Apr 23, '08
From VEGAS
as the guys said, if you replaced the clutch yourself then you shouldnt be whining at all, i know how it is getting frustrated over little things as my celi was the same thing, when i first got the car the speedometer didnt work at all, timing belt needs to be replaced, a/c had to be recharged,brake rotors had to be replaced, car overheats due to a stuck thermostat, radiotor cracked, and other things, not to mention the old owner did not take care of the car at all, dings and dents everywhere, the car was burning oil, and oil was barely changed probably every 5 months lol...good thing my uncle worked at a local toyota dealership, so he took care of the rest and now it sits wayy better than how it was 2 years ago
post Feb 21, 2009 - 11:13 AM
did you over heat it? you say the engine got hot and then you left it running?????
post Feb 21, 2009 - 11:52 AM
grasby
Joined Dec 21, '08
From jacksonville, ar
haha dude hers one way to look at it
1. you know that with all that work put into, you will enjoy driving it that much more knowing you brought it bacc to life
2. gives you a chance to learn a few things about fixing cars
3. the car always runs better when you know your the one who put it bacc together ( after a couple re-dos of course, doesnt always work right on the first fix)
post Feb 27, 2009 - 12:23 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (grasby @ Feb 21, 2009 - 9:52 AM) *
Totally true; I will never take my car to a mechanic again. I would rather do all the work myself. smile.gif
post Feb 27, 2009 - 12:43 PM
alll i got to say is if the car is hot leaving it running was a stupid idea. thats your own fault for that one.
secondly its 180k miles on it its bound to have some issues its OLLLLLLLD.
probably needs a water pump, batteries are easy. A starter is meh and not too expensive
just take some time and knock one out at a time.
this is just a lesson in you should inspect everything completely before you buy it, buying something that "needs work" for DD use is NEVER a good idea.
This post has been edited by playr158: Feb 27, 2009 - 12:45 PM
post Feb 27, 2009 - 1:20 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
i got a 94 with 281,xxx on it..
patience. this car is amazing.
post Feb 27, 2009 - 2:31 PM
6G96GT
Joined Jan 20, '08
From East Coast
It's definitely a car worthy to fix. I bought mine with 175,000 on it and it ran crappy but then I put a grand into minor to moderate fixes and it runs like a champ except now I have some smoke at startup (bad valve seals) but it's currently in the shop getting that fixed and more! I love the car, you will too. By the way I love this more than an eagle talon tsi awd I had that had over 300 whp.
This post has been edited by 6G96GT: Feb 27, 2009 - 2:32 PM
post Feb 27, 2009 - 5:24 PM
grasby
Joined Dec 21, '08
mine has about 180k miles on it
and everything started breaking down a few weeks ago
lol im in the process of replacing a few things
in the last two weeks alone i have bought:
new front cv axles
new clutch
new brake master cylinder
new ball joints
new water pump
yea, and im still not done, a few more things and it should be like new
i bought a prelude one time for what i thought was a good deal
the day after i bought it, it started falling apart
the bumper actually came off while i was driving home the next day
all the ball joints had to be replaced
along with all the brakes, new rotors all around
i ended up spending a couple hundred restoring it
after i was done tho it was an awsome little car
until some bitch hit me going 80 mph
then blamed me for the accident
the overall message is this:
if YOU put all the hours of work into it, then YOU will enjoy it more than anyone else would
post Mar 4, 2009 - 11:53 PM
xIIscrapsIIx
Joined Mar 4, '09
From Ohio
At least after you fix all these problem you can take more pride in your tuner... Better than most people that buy their rides already in perfect condition!
Scraps
post Mar 5, 2009 - 1:00 AM
alltracst185
Joined Mar 1, '09
From fitchburg, ma
I'm in mass and looking for a 6th gen. Is it a gt? Let me know if you want to get rid of it.
post Mar 5, 2009 - 12:41 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Old cars have a lot of problems. If you want something reliable get a new used car.
Lo-Fi Version Time is now: November 27th, 2024 - 1:01 PM
