> Clutch problem?
post Oct 11, 2003 - 1:57 PM
SleeperCelica
Joined Jul 27, '03
From Maine
hey guys,
Whenever i push the clutch in it makes a odd squeaking noise, then when i let it out, it does the same,
is there anyway to fix this?
thanks
post Oct 11, 2003 - 2:03 PM
SpedToe169
From Dallas, Tx
Mine does this too sometimes. Just lube the pedal pivot. Its up underneath the dash.
post Oct 12, 2003 - 12:46 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Hey i have clutch problems too. it doesn't go into first easily sometimes and it sticks it alsos grinds in reverse sometimes. Any ideas on how i can fix this? please email me at dustinb_15@hotmail.com
thanks
post Oct 12, 2003 - 12:48 PM
PowellCelica
Joined Aug 14, '03
From Knoxville, TN
QUOTE (dustin15brown @ Oct 12, 2003 - 5:46 PM)
thanks
Mine was just doing that! I put a centerforce in and it fixed the problem. But now i have a little trouble getting into second. But as far as reverse goes it totally fixed that. Although for some reason my TOB is squeeking now when i let off the pedal. But when i push the pedal down a little it stops.
post Oct 12, 2003 - 3:55 PM
Benevolence
Joined Oct 9, '02
From San Diego, CA
QUOTE (SpedToe169 @ Oct 11, 2003 - 12:03 PM)
post Oct 20, 2003 - 1:02 AM
PeetaaBlah
Joined Apr 16, '03
if you are having problem going into gears, you should check the clutch cylinders
post Oct 20, 2003 - 4:58 PM
95GTspeed
Joined Aug 13, '03
From Chicago, IL
i also have a problem
going slowly out of my driveway, my car is really shakey like im going over a lot of bumps. but, when i drove it around the block, it was fine. Even slowing down and accelerating from stop signs it was fine. This just suddenly happened because i parked my car in the driveway and it was fine. A little later i was pulling it out and it was horrible. My dad and I have guessed its the pressure plate confused.gif but were not sure.
This post has been edited by 95GTspeed: Oct 20, 2003 - 4:59 PM
post Oct 21, 2003 - 6:50 AM
Aus
Joined Sep 23, '02
mine makes that squeaky sound to!! (Really irritating)
and also sometimes 1st and reverse don't go in properly.
1996 UK white ST205
1998 UK silver ST202
post Oct 21, 2003 - 8:51 AM
blkGT
Joined Jun 10, '03
From FL
QUOTE (dustin15brown @ Oct 12, 2003 - 10:46 AM)
thanks
Well in our cars u cant get into first/and shouldnt until your going about 5 mph. Also reverse is sometimes hard for me and I just got a new clutch, try putting it into 5th and then down to reverse.
Lo-Fi Version Time is now: November 27th, 2024 - 8:56 PM
