![]() Enthusiast ![]() Joined Apr 23, '08 From VEGAS Currently Offline Reputation: 1 (100%) ![]() |
hi guys sorry but i need help removing the headliner, my sunroof is stuck and i wnna fix it, i tried searching for it in the how-to section for any sticky but i didnt find anything, if you guys can post a how-to or pics to show where the screws are itll be much appreciated..thanks in advance guys
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
Remove plastic pieces on the sides
Remove visors and visor clips Remove rear view mirror Remove map lights Remove 3 fasteners in the rear Edit: You might have to remove trim around the sunroof... idk, I don't have one. This post has been edited by Cutrara: Mar 13, 2009 - 12:08 AM -------------------- |
Enthusiast Joined Apr 12, '09 From Brooklyn NY Currently Offline Reputation: 0 (0%) ![]() |
no diys for this?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
Its really not that hard (unless you own a coupe). I coulda sworn that AkiraD and myself put something up on here regarding headliner removal (although it was more geared for sunroof stuff). Its easy though. Remove the "a" pillar moldings, remove three plastic screws in the back (by the window), remove rearview mirror, remove visors and the clips that hold them in, remove sunroof/map light housing, loosen the plastic trim in the back after you remove the coat hanger things. Then if you have a sunroof, take off that little piece of trim. If you own a hatch, it shuld slide right out the back. If you happen to be like me and own a coupe, you might wonder how to get it out once you get it removed. I just layed both seats flat, and gently removed it by pulling it out at a weird angle.
This is the part DYI I was talking about. This post has been edited by Spider77: Jun 10, 2009 - 6:52 PM |
Lo-Fi Version | Time is now: April 23rd, 2025 - 7:37 AM |
