> dash work
post Mar 24, 2009 - 7:15 PM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
so i had an idea the other day to mess with the bucket thing under the radio. i cut a piece of clear plastic to fit over it and cut out a celica dragon in the middle. im smoking out the plastic right now. but im planing on putting a red neon behind it hooked up to a music interface. what you think?
post Mar 25, 2009 - 5:17 AM
korban
Joined Feb 5, '09
From New Zealand
Hey that could look awesome lit up! Does the glue look as bad in real life? Look forward to seeing it installed.
post Mar 25, 2009 - 3:33 PM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
yes the glue is horrendous, that would be why im attacking it with VHT. in the proscess of tinting it now should be done in a little bit.
post Mar 25, 2009 - 7:48 PM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
so its almost done it took 7 tries to tint just cause im an idiot all i need to do now is get a red neon and im done
post Mar 26, 2009 - 2:47 AM
korban
Joined Feb 5, '09
From New Zealand
Ahh, nice one!
post Mar 26, 2009 - 11:40 AM
Legit94GT
Joined Feb 6, '08
From Oregon
that looks real nice!!! good work
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Mar 27, 2009 - 9:33 AM
you may want to smooth it out, and sand it, but i like it.
post Mar 27, 2009 - 8:10 PM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
the problem is tint doesnt like to be sanded and thats why i had to tint it so many times. i just cant find a damn neon light to fit behind it.
post Mar 27, 2009 - 8:39 PM
Bigblock
Joined Feb 14, '09
From Mid West
Very original!! The only lights I've seen that may work are L.E.D. unless you want to figure how to wire a colored 194 bulb and socket. Great idea & good luck.
post Mar 28, 2009 - 1:23 AM
92-gt
Joined Jan 22, '09
From Bremen
It wouldnt be hard to wire some 194 sockets in there. You could hook it up to the radio power and it would come on then, or wire it to a switch.
Just go to a junkyard and grab some 194 sockets, and get some leds from superbrightleds.com
post Mar 28, 2009 - 12:18 PM
Bigblock
Joined Feb 14, '09
From Mid West
I tried to go to Streetglow.com--I see they have all sizes/colors neon.I can't catalog browse .for some odd reason it won't load. Check it out if you haven't.
post Apr 3, 2009 - 8:10 PM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
im done finally. i went and got some leds from autozone and hooked them up to the interface
had a problem with the lights. the bucket so i had some chrome paint so i sprayed the inside, less black = less light absorption.
taped the lights onto the back
taped the interface behind everything
hooked it up to the stereo remote wire and ground wire
pics
post Apr 3, 2009 - 8:30 PM
Props for taking the time to try and do something custom... but the actual piece needs a bit more work.
post Apr 4, 2009 - 3:30 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
QUOTE (lagos @ Apr 3, 2009 - 8:30 PM) *
x2, maybe more flush mounted? it looks good with the light off though, really cool.
post Apr 6, 2009 - 10:50 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
Cool idea. It looks good. But the lines of the dragon need to be cleaned up a bit, smoothen out all the rough lines and it'll look great.
And i apologize for criticizing as I could never do that, my hand is shakier than a 70 yr old man. biggrin.gif
My F/S Thread!
Ferdi says (11:29)
post Apr 7, 2009 - 6:50 AM
twinkletoestheir...
Joined Dec 15, '08
From lexington ky
yeah the details are just so small that i used a dremel 3/32'' ball point cutter. i need to redo the nightshade anyway so when my new can comes in ill clean every thing up. thanks for the advice.
post Apr 7, 2009 - 2:14 PM
SoundSlut_dotcom
Joined Feb 16, '03
OR.. maybe you can make up or find a sticker or make a stencil out of it.. get a clear piece of plexy glass and just spray around it.. then peel it off to ge tthe same effect .. either way , great idea
Lo-Fi Version Time is now: November 23rd, 2024 - 10:42 AM
