Powerwashing engine, how to do it safely |
Mar 27, 2009 - 12:38 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
Ive been told to powerwash my engine in order to clean it up so i can locate an oil leak.
so does anyone know the proper procedures to do so? Just to make sure i dont damage anything electrical i would have to assume you have to keep something dry... -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Mar 27, 2009 - 12:41 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
the biggest things u have to worry about is getting water in your intake, and distributor, so ducktape a plastic baggie aroung your distributor and the intake filter if u have an sri. other than that have at it! lol
This post has been edited by Ryouxrs: Mar 27, 2009 - 12:41 PM -------------------- Lift Addict!! ^_^
Mar 27, 2009 - 12:43 PM |
i had heard that i need too keep the engine running so i dont get water on the sparks
and what about the alternator? i feel like that is very exposed -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Mar 27, 2009 - 1:16 PM |
Ive been told to powerwash my engine in order to clean it up so i can locate an oil leak. well just use brake parts cleaner to locate where your leak is. but at the same time its a good idea to wash engine if you'd like. when i did it. i dont remember duct taping/covering the alternantor. i covered up electrical parts that were under the hood like injectors and eletrical wires that were near injectors, duct taped throttle body. also use engine decreaser and shine. -------------------- Group buy to replicate Narrow E series transaxle parts
Mar 27, 2009 - 1:38 PM |
u dnt have to worry about the alternator, it will be fine. DO NOT have the engine running when u wash it. u will almost for sure short something out or damage electrical components if you do, just cover those 2 things realy good, and u shouldnt have any problems.
Mar 27, 2009 - 2:38 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
Once washed is it safe to drive? Or should you wait till its all dry?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Mar 27, 2009 - 3:24 PM |
u could drive it right away if u seal off those 2 things
Mar 27, 2009 - 4:38 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
If by power washing you mean using a pressure washer, be careful around all the plastic clips for electrical plugs. the plastic will be very brittle because of years of putting up with the engine heat, alot of mine break off in my hand, so I wouldn't want to imagine what water at 2000psi would do to them.
IMO you'd be better off with a strong degreaser, maybe a sponge to scrub around and just a normal hose. This post has been edited by samir0189: Mar 27, 2009 - 4:40 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Mar 28, 2009 - 1:10 PM |
Enthusiast Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
Blow air with a compressor after you cleaned it so it will dry faster
Lo-Fi Version | Time is now: December 4th, 2024 - 5:23 PM |
