> best engines!!
post Mar 29, 2009 - 4:20 PM
moveon622
Joined Mar 24, '09
From Wentzville Missouri
what is the fastest, best engine to put in my 96 st?
post Mar 29, 2009 - 4:22 PM
1UZ-FE.
post Mar 29, 2009 - 4:36 PM
moveon622
Joined Mar 24, '09
QUOTE (Bitter @ Mar 29, 2009 - 5:22 PM) *
1UZ-FE.
just to clarify, i am looking for an engine i can drop in, this does not require and modifications does it? alot of these seem to be in supras, a rear wheel drive car....will the engine work in my car seeing as though it is front wheel drive?
This post has been edited by moveon622: Mar 29, 2009 - 4:36 PM
post Mar 29, 2009 - 5:11 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
sorry, I'm going to be a dick here. RESEARCH!!!!
THERE IS A SEARCH BUTTON AT THE TOP!! THERE ARE STICKIES IN EACH FORUM FOR THIS ****! SAME WITH YOUR SHORT SHIFTER POST
post Mar 29, 2009 - 5:31 PM
trdproven
Joined Aug 2, '05
From Guam
^ lol Brady. But its right there is a search function and plenty stickies and threads to answer your question. Typically for your ST a 4age gets dropped in. Research on what specific 4a. You could get a 3s as well but you will have to do that research on your own.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 29, 2009 - 5:54 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
check stickies... engine swaps are covered indepth
Breaking Axles...
post Mar 29, 2009 - 6:05 PM
97celiman
Joined May 22, '08
From dallas texas
also if you think the 1uzfe is whats in supras you REALLY REALLY REALLY need to do some reading, tons of step by step threads here
side note i believe you are thinking of 1jzgte
post Mar 29, 2009 - 6:25 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
1UZ - SC400/LS400
1JZ - Supra/Chaser/Soarer
The V6 you want is what came in the Camry and Solara, which is the 1MZ-FE. And "best engine" is an opinion and could be based on performance, reliability, efficiency, etc.
This post has been edited by GotToyota: Mar 29, 2009 - 6:26 PM
post Mar 29, 2009 - 7:07 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
how about 1gz-fe... 5 litre toyota v12...should fit straight in hahaha.
GRX133 Toyota Mark X 350s
post Mar 29, 2009 - 8:16 PM
Takbu
Joined Mar 29, '09
From HK
QUOTE (moveon622 @ Mar 29, 2009 - 4:20 PM) *
post Mar 29, 2009 - 9:19 PM
QUOTE (Takbu @ Mar 29, 2009 - 9:16 PM) *
IDK about that, i recently tried a 3sgte swap, and i think its worth it.
post Mar 29, 2009 - 10:35 PM
Takbu
Joined Mar 29, '09
From HK
QUOTE (njccmd2002 @ Mar 29, 2009 - 10:19 PM) *
It will be more powerful if u swap a 3SGTE with say 245PS, but u have to solve the understeering problem if your Celica is a FWD. Cos I got a parts car ST215 Caldina turbo M/T for my engine swap, but my car is also a FWD, so i still could not make the decision.
post Mar 30, 2009 - 2:01 AM
oh man, its fun to have all the hp under the hood.
After driving the swap, and driving my car, i now know the stock engine is severely underpowered...
post Mar 30, 2009 - 3:01 AM
Rusty
Joined Nov 5, '07
From New Zealand
Beams VVTI 2.0L 3SGE
kindasad.gif 3rd GEN ftw
but then if you want more power?? ^^ others ideas
post Apr 2, 2009 - 3:04 PM
Toyota_Celica_97
Joined Sep 25, '08
From california
i say gt-4 3sgte if you want turbo.
n/a i say go with the V6 1MZ-FE.
post Apr 2, 2009 - 3:15 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
way to welcome a new member guys
New guy: "best" is highly subjective. IDK if one is "better" than another. It just depends entirely on what your needs and goals are for your car.
Some motors to research are going to be a 3sgte, a 4age - both Blacktop and Silvertop, and a 4agze. Beyond that it gets into heavy customization which sounds like something you're trying to avoid. The 3sgte will get you the most HP, but the 4age and 4agze is a better swap candidate for an ST if you're not wanting to do too much modding to accommodate the motor. I'm not so sure any of them is as simple as a straight swap though, but it's a lot closer w/the 4age.
post Apr 2, 2009 - 10:31 PM
RavenAegis45
Joined Jun 25, '08
From CA
I have to agree that there is no such thing as simply a "BEST" engine. Each engine is different and how you modify it also has pretty significant effects. Usually making High End power hurts low end torque and what not. But simply speaking for your ST a 4A-GE engine swap would probably be the easiest since your car has an A Series Engine. but your going from a 1.8L to a 1.6L which means torque would take a sick beating but the top end is pretty good for those engines. Of course you can find a wrecked GT at a Junk yard and swap the 5S-FE in, its not the fastest engine nor gets the greatest mileage but its got pretty good drive-ability patterns thanks to its 2.2L displacement. Then again you can swap in a JDM or EDM 3S-GE which makes alot more top end than a 5S-FE or 4A-GE. but again its low end power isn't as good as a 5S-FE because its a smaller engine being 2.0L so drive-ablity is again hurt. But then again you always have the option of getting a 3S-GTE which has power all across the rev range but suffers from turbo Lag, at least non rally cars do from what I hear. Or you could do a V6 swap from a camry but these are a little more complicated but drive-ability is second to none. especially if you mod it correctly. And you'd get great top end. Simply put your choice of engine depends on how you'd like to drive. A daily driver wouldn't make top end to be a great race car yet a Track car would suck in traffic. The Choice is yours
This post has been edited by RavenAegis45: Apr 2, 2009 - 10:35 PM
post Apr 2, 2009 - 11:26 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
just throw in a skyline engine cant be that hard=p
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Apr 3, 2009 - 4:08 PM
satelite
Joined Apr 25, '06
From Santo Domingo
3s gte/ 3 gen you dont need any more. For experience its the best engine for thes Celica.
i have it in my car and is the best.
post Apr 3, 2009 - 6:44 PM
gomezjose26
Joined Feb 11, '09
From houston
a h22! woot.gif lo jk ummm the 3sg dude.
Lo-Fi Version Time is now: February 16th, 2025 - 8:11 AM
