HELP..Back end noise, thumbing noise at the back of car |
Mar 30, 2009 - 4:09 PM |
Enthusiast Joined Mar 23, '09 From texas Currently Offline Reputation: 0 (0%) |
Hello fellas,
Someone help me please. There is a loud noise coming from the rear part of my car 94 ST at the passenger end. Anyone had this issue and what was the diagnosis and solution fix. Please help. THANKS |
Mar 30, 2009 - 5:04 PM |
Enthusiast Joined Nov 15, '07 From Attleboro Mass Currently Offline Reputation: 1 (100%) |
What does the noise sound like? A pop? Creak? Groan?
-------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Mar 30, 2009 - 5:11 PM |
Enthusiast Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
does it happen all of the time? under a specific speed? only when braking?
I would get a pop/clunk when I would apply the brakes. turned out that one of the two bolts that holds the rear calipers on had fallen out, and the caliper was hanging back off the rotor. a new bolt corrected this. edit: you have an ST, so you wont have disc brakes in the rear, but that doesnt mean it couldnt be brake related. however my assumption is suspension related. This post has been edited by 95CelicaST: Mar 30, 2009 - 5:13 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
I'm not really an asshole, but I play one on the internet. **** Photobucket |
Mar 30, 2009 - 5:36 PM |
It sounds like a groan. Like something is moving around. Mech said i might need new struts. quote name='6GenCelicaST' date='Mar 30, 2009 - 5:04 PM' post='764957'] What does the noise sound like? A pop? Creak? Groan? [/quote] Mech said i might need new rear struts will take tomorrow to have it properly checked out Which will be a great brand to purchase. |
Mar 30, 2009 - 8:36 PM |
Enthusiast Joined Mar 29, '09 From South Lyon, Michigan Currently Offline Reputation: 0 (0%) |
Could be a exaust hanger that broke and is allowing the muffler or exaust pipe to hit the under carrage.
Apr 1, 2009 - 11:47 AM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
every celica i've ever owned has had a continuous poping while driving, its annoying but nothing ever fixes it, new struts didn't fix it in my old vert. and when i put new struts/swaybar endlinks on the black one it was still there :S
Apr 1, 2009 - 12:18 PM |
If it's the struts, try searching the forum to see all the varying opinions on which struts to replace them with. There's tons of threads about suspension.
QUOTE every celica i've ever owned has had a continuous poping while driving, its annoying but nothing ever fixes it, new struts didn't fix it in my old vert. and when i put new struts/swaybar endlinks on the black one it was still there :S Funny, when I needed to replace my rear struts so badly, I had the "thump thump" but not the pop you're talking about. I know which sound you're talking about though, because only AFTER I replaced my rear struts, all my springs, rear sway bar bushings and rear endlinks (twosRus FTW!) did I get that 'pop' sound. It usually only does it in the morning when the car is cold and has been sitting all night though. -------------------- |
Apr 1, 2009 - 12:24 PM |
Enthusiast Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) |
I have that very same problem.. thug sound when accelerating and slowing down... not braking but slowing down. My theory is the rear strut mounts or the strut mounts are not aligned to the struts.
-------------------- -Derick
"In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Apr 1, 2009 - 12:44 PM |
I actually think the same thing, that the struts are seated improperly on the rubber thingie on the mounts. It's actually not something that really stresses me out too much; I know it was all lined up when I put them in there, so it probably shifted a bit when I pushed them up into position to bolt them in.
Apr 1, 2009 - 1:37 PM |
Enthusiast Joined Dec 6, '08 From Oregon Currently Offline Reputation: 0 (0%) |
rear stuts...simple as that.
-------------------- "What does All-trac mean?....."
umm.......kicks ass! ST165 1988 Celica All-Trac ST204 1995 Celica GT (undergoing GT-Four conversion may 23rd.) |
Apr 2, 2009 - 10:18 AM |
I got 4 mo. old kyb's, I'm going to check strut mount alignment this weekend. I'll update this if the thumpipng noise goes away.
Lo-Fi Version | Time is now: November 27th, 2024 - 2:39 AM |
