4age swap to 7afe 16v |
Apr 7, 2009 - 10:28 AM |
Enthusiast Joined Mar 31, '09 From allentown Currently Offline Reputation: 0 (0%) |
i just received a 4age motor and tranny.16v. for free it jus needs a head gasket. i will be rebuilding it though. i also have turbo kit i might throw in. but might do all motor. what would i have to buy to make this conversion work. i know it bolts right up . i just need to know how to make the wire harness work and powersteering. ac no big deeal idk if i want to keep it. and i still have my 7afe engine. i aam going to end up giving it away to after im done with this motor swap. i just need help and maybe ill give it you the motor.
thanks isaac |
Apr 7, 2009 - 11:22 AM |
Enthusiast Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
talk with dr tweak he can help with the wiring harness
Apr 7, 2009 - 11:48 AM |
I believe you can use the stock harness and ECU off the 4age; otherwise, you'll need the ECU and Dr Tweak can help w/the harness.
Apr 7, 2009 - 12:47 PM |
considering this swap to be easy for st celica's. i was told in another thread that the gearing for 4age blacktop is shorter and the final gear is longer. anybody know what blacktop can top out at?
-------------------- Group buy to replicate Narrow E series transaxle parts
Apr 7, 2009 - 2:38 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
You need to make a custom hose for the top of the radiator because it will not fit / too short. Unless you can source an 89-91 GTS corolla Radiator and the upper hose.
Apr 7, 2009 - 4:33 PM |
so if i use the 4age ecu i dont have to mod the 4age wire harness at all?
Lo-Fi Version | Time is now: November 27th, 2024 - 12:27 PM |
