Compilation of nonoem 20v plug part numbers |
Apr 16, 2009 - 9:31 AM |
Enthusiast Joined Jun 18, '07 From Atlanta Currently Offline Reputation: 0 (0%) |
Here are most of the 20v's (and many other toyota's) nonoem part numbers. There are 3 main manufacturers involved:
Yazaki: Igniter 7283-1056-30 knock 7283-1015-10 coil 7283-8226-30 airtemp 7283-1224-10 vvt 7283-7526-40 receptical tab/terminal 7116-4025 seal 7157-3646 Sumitomo: evap 6189-0249 injector 6189-0573 map 6189-6912 camposition (will update) O2 (will update) Tyco: 12pin ecu plug 917978-1 16pin ecu plug 917981-1 22pin ecu plug 917989-1 26pin ecu plug 917992-1 tps plug 178399-2 watertemp 178392-6 receptical tab/terminal small 175265-1 receptical tab/terminal large 175269-1 So there's 90% of the connectors and parts in a 20v harness. Other toyota harnesses have a lot of this stuff in common. Most of these can be had from various suppliers around the internet. I'm working with a supplier who will provide them all at once to simplify things. I really don't want to be in the electrical supply business. Basically it will allow a "new" option with my harnesses. Of course, with this info, even a Diy'er will have "new" capabilities. Some of these connectors are readily available in the junkyard. For example, the map and iat plugs can be found on nearly any toyota that used a map sensor. It still takes a fair bit of skill to make a harness, but I'm sure to some of you, this info will be extremely helpful. This post has been edited by mr220v: Apr 16, 2009 - 10:53 AM |
Dec 31, 2009 - 2:56 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
It is possible to identify the manufacturer of the connector housing or loom assembly by the logo on the part:
Yazaki (often just the arrow/eye logo without the accompanying text) Sumitomo Tyco ??? This post has been edited by BloodyStupidDavey: Dec 31, 2009 - 5:45 PM -------------------- Davey
Items for sale |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:53 PM |
