> Torque steer, car pulls to right
post Apr 22, 2009 - 10:35 AM
Coligion
Joined Sep 27, '07
From Tucson, AZ
Just as the title says, I have excessive torque steer. I've had the car aligned multiple times in the past two years with no success. The car is under spec for alignment, but still wants to pull to right; I have even installed camber bolts to compensate for the pull. The reason I believe it to be torque steer is because when the car is cruising in neutral, or no gas is applied, it will drive perfectly straight. Only when the gas pedal is pushed down will I get the pull. I have checked the control arms and tirerods and they appear to be just fine. Any suggestions? This member also had a similar problem...
http://www.6gc.net/forums/index.php?showto...hl=torque+steer
post Apr 22, 2009 - 12:19 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Did you have your control arms tightened down as suggested in the thread you linked to?
post Apr 22, 2009 - 2:07 PM
hold on to your wheel tighter
post Apr 22, 2009 - 3:05 PM
Your control arms are loose.
post Apr 24, 2009 - 10:46 PM
Coligion
Joined Sep 27, '07
From Tucson, AZ
QUOTE (lagos @ Apr 22, 2009 - 3:05 PM) *
Checked them again last night and everything is lock-solid tight. Could a bad motor mount affect alignment? Any other ideas?
post Apr 25, 2009 - 1:48 AM
azian_advanced
Joined Apr 18, '05
From Calgary
doesn't hurt to check...
what if you're on a surface that is inclined down towards the left (passenger side higher than the driver side), does it still torque steer to the right?
i get some torque steer too but it really hasn't bothered me much... not enough to think that there's something wrong with the car.
post Apr 25, 2009 - 8:28 AM
trdproven
Joined Aug 2, '05
From Guam
was it ever in some sort of collision before you had it?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 28, 2009 - 6:52 PM
Coligion
Joined Sep 27, '07
From Tucson, AZ
QUOTE (azian_advanced @ Apr 25, 2009 - 2:48 AM) *
Yeah, it certainly helps counteract the pull to the right, but it still wants to veer in that direction. No, the car has not been in any sort of accident. The only thing I can think of is that maybe I ran over some huge pot-hole when I first got the car (it has been this way a long time)? If something was bent I imagine that could cause problems. Would a mechanic be able to diagnose something like that?
Lo-Fi Version Time is now: December 3rd, 2024 - 9:42 PM
