> idle problems, My car is idling very oddly
post Apr 22, 2009 - 8:07 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
Whenever I turn my car on the rpm's are at 2 and they'll stay there, if I brake hard they may start going up and down between one and two thousand. Any ideas anybody?
post Apr 22, 2009 - 8:12 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
You may have a vacuum leak. Go and check out all of your vacuum lines.
post Apr 22, 2009 - 8:17 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
alright I'll do that first thing in the morning thanks.
post Apr 23, 2009 - 10:50 AM
celicast95
Joined Dec 3, '08
From Superior, Wisconsin
Ive got this same problem frown.gif its extremely annoying when your sitting in trafic and your car is constantly reving up, makes me look like a tool. lol
1995 Toyota Celica St- Sold!
1994 Toyota Celica Gt- Sold!
2001 Honda F4I- Sold!
1992 Lexus sc300 5spd!!
post Apr 23, 2009 - 5:20 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
QUOTE (celicast95 @ Apr 23, 2009 - 9:50 AM) *
laugh.gif omg, that sucks, but anyways, check for vaccum leaks first, try using a squirt bottle full of soapy water, or a can of carb cleaner, spray down all of your vaccum lines, and intake gaskets, if/when u hit the leak with the fluid u are spraying the idle will change, carb cleaner works best. if u dnt find any leaks then test your map/maf, tps, and iacv.
This post has been edited by Ryouxrs: Apr 23, 2009 - 5:21 PM
Lift Addict!! ^_^
post Apr 23, 2009 - 6:03 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
I've found one torn hose, it's supposed to be connected to the charcoal canister.. A friend told me that I should clean out my Egr valve, that that may have something to do with it.
This post has been edited by Maxtumare: Apr 23, 2009 - 6:07 PM
post Apr 23, 2009 - 7:00 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
Alright cleaned out my throttle body and reconnected that hose. By doing this I raised the idle to 3k............ so I'm starting to think maybe it's the tps.
post Apr 23, 2009 - 7:49 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
your maf, and or tps may be the issue, have them both tested, if u have acces to alldata or mitchel under sensor diagnostics u should be able to find the proper resistance values for those sensors, or a chilton manual may have the same info on how to test them. hope this helps
Lift Addict!! ^_^
post Apr 24, 2009 - 7:34 AM
QUOTE (Ryouxrs @ Apr 23, 2009 - 8:49 PM) *
what MAF?
post Apr 24, 2009 - 11:04 AM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
lol, i thought the 5sfe's had mass air flow sensors, thats why i said maf/map sensor lol, wasnt sure wick one u have
Lift Addict!! ^_^
post Apr 24, 2009 - 9:05 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
Would somebody please explain to me how I can adjust my tps? if it is possible to do so.
This post has been edited by Maxtumare: Apr 24, 2009 - 9:14 PM
post Apr 25, 2009 - 2:18 AM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
take your intake tube off and start your car, and look at your throttle plate at idle, it should be almost closed, if its open then something is binding, try that first.
Lift Addict!! ^_^
post Apr 25, 2009 - 10:28 AM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
O well it's almost closed and everything is pretty straight, but I figured I'm just going to give in. Damn so it's at the mechanic today.
post Apr 25, 2009 - 12:07 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
let us know, and if the figure it out, just take it home and fix it yourself, save yourself some money
Lift Addict!! ^_^
post Apr 27, 2009 - 10:54 PM
Maxtumare
Joined Jul 16, '08
From miami, fl, usa
QUOTE (Ryouxrs @ Apr 25, 2009 - 12:07 PM) *
Yup it was the iac.
Thanks guys problem solved
post Apr 27, 2009 - 10:58 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
Lift Addict!! ^_^
post Apr 28, 2009 - 11:03 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
good to hear
This post has been edited by rjbibeau: Apr 28, 2009 - 11:05 AM
post May 8, 2009 - 2:19 AM
Bellakelpie
Joined Jun 27, '08
From Geelong, Victoria, Australia
Is the iac replaceable, or did you have to have a complete replacement throttle body fitted?
post May 28, 2009 - 7:12 AM
Bellakelpie
Joined Jun 27, '08
Just had my 6G repaired after it started to do exhibit the exact same problem.
Local name for the faulty component was the "Idle Motor." (read "Servo")which is mounted in the throttle body unit.
Toyota Genuine Part was priced in excess of $Aust 600.
My repairer fitted a non genuine (but made in Japan) unit, at 1/2 the cost. (Go figure-- who is making a buck here)
Problem solved now.
Lo-Fi Version Time is now: February 21st, 2025 - 8:44 AM
