> Exhaust bogs after highway run ??, Clogged Cat ??
post May 7, 2009 - 5:57 PM
Lone_Wolf
Joined Apr 22, '09
From Work
Hi, I have question after a highway run and I come to a stop my car would shake underneath not sure where but seems like its coming from the exhaust like somethings clogged in it or something could it be the the cat converters ?? I know we have 2 but not sure if thats the problem ?? And before I installed my header my car would hesitate before acceleration does that also mean the 1st cat that is on the exhaust manifold is clogged ?? Because after I put on the header I notice the hesitation goes away ?? Thanks
**If you can read this you are too close**
post May 7, 2009 - 7:22 PM
if you floor it, does it accelerate or just bog? have a friend rev the engine and see if the exhaust is flowing out.
post May 8, 2009 - 4:14 PM
Lone_Wolf
Joined Apr 22, '09
From Work
It bogs and then takes off, their is air flowing out of the exhaust.
post May 8, 2009 - 9:36 PM
sounds more like an ignition issue, check the usual ignition parts.
post May 8, 2009 - 10:30 PM
Lone_Wolf
Joined Apr 22, '09
From Work
I just put in a new rebuild dizzy my denso spark plugs are 7 months old and my NGK wires are 1 year old they all tested fine ?? No CEL's too. I'm running out of parts to test. tongue.gif
post May 9, 2009 - 3:55 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Rotor and cap?
post May 9, 2009 - 8:40 AM
igniter? maybe you should diagnose rather than just replace parts.
post May 9, 2009 - 10:32 AM
Lone_Wolf
Joined Apr 22, '09
From Work
The new distributor came with a new rotor and cap I needed a new dizzy thats why I replaced it, I already checked the igniter too.
post May 9, 2009 - 7:50 PM
well if you're sure the ignition is 100%, how about fuel system?
post May 9, 2009 - 8:44 PM
Lone_Wolf
Joined Apr 22, '09
From Work
My fuel filter is 2 years old I should probably change it the only way to test it is too take it out anyways and while its out I might as well replace it since I'll have to get new gaskets for it lol. I've never changed the FPR or the o-rings on the injectors I do run fuel system cleaner in my tank every 3k, you think that could be the problem ??
post May 9, 2009 - 9:11 PM
just running down the list
Lo-Fi Version Time is now: February 19th, 2025 - 11:55 PM
