> OEM toyota oil filter vs the rest
post Jun 24, 2009 - 1:03 AM
mk7celica
Joined Feb 2, '09
From new orleans La.
Ok so I read in another thread on oil filters. I just installed a stp oil filter. Is it better for to get a toyota oil filter because it runs oil through faster because of its design? And my stp oil filter I have now dont is this true? I think It was in a thread about oil pressure not being made right away without a oem filter. I was wondering if I need a oem filter right away?
post Jun 24, 2009 - 1:38 AM
your engine has been running for close to 20yrs so far. over its life time it has had a lot of different oil filters on it and it has survived just fine till now. no need to panic. smile.gif
post Jun 24, 2009 - 3:39 AM
Hanyo
Joined Aug 16, '03
From Bay area
all the old filters on the market are made by only a few manufacture and re-branded to certain markets.
There are obviously different materials/ design differences, but they all provide the basic fit and function.
The reason you would want to pay more for a filter is 1) your getting a better filter material inside and 2) the oil drain back valve design.
What the drain back valve does, is it keep the oil inside the filter when your car is off. So when you start your engine in the morning it provides some reserve oil for your engine until you get oil pressure. The second purpose of this valve is to let oil pass through it when the filter is clogged so you don't blow up your engine.
So in a brief explanation, if you keep up on your car maintenance up. You really dont need to worry about what oil filter you use. Because your oil filter will not fail on you with in 3k-5k miles.
If your paranoid like me, but a premium oil filter. But there is no guarantee that the better filter is not a dud off the shelf.
post Jun 24, 2009 - 8:19 AM
DEATH
Joined Dec 19, '07
From tx
Lagos is correct - However, you are also correct. Many of the oil filters still sold in today's market do not have this very important feature but not any one oil change worth of starts is going to ruin your motor. It is a good practise [and advised by many people on here] to always use Toyota OEM filters because there is no guesswork involved - there will always be an antidrain back valve [otherwise known as a check valve]. As a designer of lubrication check valves I can tell you it is a very important part of the lubrication system but don't panic, as Art said, if you don't have one on your car currently - just make sure you have one next time.
It's also highly possible that the STP filters have this feature [equally possible that they don't]. You'll be fine
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jun 24, 2009 - 12:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (DEATH @ Jun 24, 2009 - 8:19 AM) *
agreed. i have been using OEM filters lately, and the oil light goes off noticeably sooner smile.gif
post Jun 24, 2009 - 1:43 PM
jimmykay
Joined Jul 14, '08
From St. Louis
on the other side of the coin, i've put nearly 100k miles on my car with regular fram filters( 151k total on the car). i've even gotten pretty good at catching the oil out of the filter with a rag. however, on my next oil change i plan on using a toyota one just because i recently installed the ebay header and don't want to chance leaking extra oil on my header wrap.
Of course after saying this, I'll probably not get around to picking up a toyota oil filter before I change my oil and i'll just end up using another fram one.
'99 Celica GT - Sold
'11 Mazdaspeed3
post Jun 24, 2009 - 3:08 PM
DEATH
Joined Dec 19, '07
From tx
Um - Fram is about the worst filter you can pick for our cars - they def don't have a checkvalve. You are underlubing your motor during startup and shortening the lifetime of you engine.
Switch to OEM filter - they are $5 for god's sake [2 for $5 is you catch them on sale and stock up like I do]
EXT: WRC/TRD/404
post Jun 24, 2009 - 4:55 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i personally do like the K&N... it does show noticeably 5-7 psi higher on oil pressure... however you are also paying buttloads more for it
Breaking Axles...
post Jun 24, 2009 - 5:50 PM
92-gt
Joined Jan 22, '09
From Bremen
Fram- They have a piece of cardboard where good filters usually have check valves. Their filter elements are JUNK. Fram filters are crap.
Toyota filters- Good quality filter element, and they do have a check valve. They can be bought for ~$5 from the dealer. They are the best bang for the buck.
K&N- Good quality throughout. Plus they have that handy nut welded on the top for easier removal. The downside is the price.
PureOne(advance auto)- Good quality element, check valve, and grippy casing for easier removal. They are around the same price as OEM filters.
I use either OEM or PureOne filters. I have used a K&N filter before, but thats because I got it from a friend brand new for $5.
Oh, and I have seen the inside of these filters before. When I took an automotive class, we cut several filters open as an experiment.
post Jun 26, 2009 - 11:37 AM
samir0189
Joined Mar 8, '08
From Orlando, Florida
ive been using fram filters since i got my car, at about 180k, and now the car has 260k, never rebuilt, doesn't burn any oil, the oil stays extremely clean and i run 7000 mile intervals on my oil. (mobil1 10-30 synthetic)
Bottom line, id say it doesn't matter the least bit. If the engine is gonna fail it wont be cause of the oil filter.
My F/S Thread!
Ferdi says (11:29)
post Jun 29, 2009 - 4:04 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (samir0189 @ Jun 26, 2009 - 11:37 AM) *
Breaking Axles...
post Jun 29, 2009 - 4:49 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (pittfirefighter @ Jun 29, 2009 - 2:04 AM) *
Pittfirefighter, I love how your replies are so useful laugh.gif you simply state something and never explain why.
samir0189, oil filters can cause an engine to blow up. If the pressure releave valve in the filter is faulty, it will cause the oil filter to essentially clog up and give your engine ZERO oil. But chances of that happening is slim simply because most people change there oil before the oil filter element is fully compromised.
post Jun 29, 2009 - 5:37 AM
samir0189
Joined Mar 8, '08
that would not be the oil filters fault. At that point it is the drivers fault for failing to change the oil. The oil filter is only designed to be used for so long before the element is clogged, it states that, I don't understand how that'd be the filters fault? Also if you are using a decent quality oil It should coat the engines internals to protect it for those few seconds of low pressure from those filters wihout check valves.
I've also had an experience where the dealership put the wrong filter on an engine, needless to say they swallowed the cost of replacing the engine, labor and all.
The oil filter can cause the engine to fail in cases like that, but under normal use with proper care and proper intervals it isn't gonna fry the engine.
No I do not work for fram but I really can't say their filters are so bad -insert something here-. With the amount of wear on my motor and using these things for so long I have nothing but good to say about them.
Why is this in forced induction?
This post has been edited by samir0189: Jun 29, 2009 - 5:40 AM
My F/S Thread!
Ferdi says (11:29)
post Jun 29, 2009 - 9:40 AM
because the OP has a turbo motor.
post Jun 29, 2009 - 10:05 AM
samir0189
Joined Mar 8, '08
okie dokie then.
Not gonna chime in on the discussion eh? tongue.gif s'ok, i know you like your oem yota filters too Manny. biggrin.gif
My F/S Thread!
Ferdi says (11:29)
post Jun 29, 2009 - 10:55 AM
QUOTE (samir0189 @ Jun 29, 2009 - 10:05 AM) *
okie dokie then.
not really.
only think i can add is that i used a purolator pure one filter when i was breaking in the motor, it must have been defective, cause i had 0 oil pressure.
like litterally, 0.
pulled that filter, stuck the old one back on, and all was well.
OEM FTW.
post Jun 29, 2009 - 10:59 AM
samir0189
Joined Mar 8, '08
Yep i recall reading that. And I can't argue with OEM being ftw either, after all it was made for our engines by toyota. smile.gif
This post has been edited by samir0189: Jun 29, 2009 - 11:00 AM
My F/S Thread!
Ferdi says (11:29)
post Jul 10, 2009 - 9:52 AM
samir0189
Joined Mar 8, '08
I just read my new Fram filters box, and it says it does have an anti-drainback valve now, the box is new, the filter is gold now, so maybe they redesigned?
http://www.fram.com/oil-filters/xtended-guard.php
They also list it on the site.
No, I didnt cut open the filter to check, and I do take it with a grain of salt, my parents always told me "the fisherman will never say his fish is bad" lol. wink.gif
My F/S Thread!
Ferdi says (11:29)
post Jul 10, 2009 - 10:16 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE (samir0189 @ Jul 10, 2009 - 9:52 AM) *
That's good - it's about time really. Are they still cheap?
I'll buy one here at work next time we do filter testing and I'll cut it open and share the results.
EXT: WRC/TRD/404
post Jul 10, 2009 - 10:22 AM
samir0189
Joined Mar 8, '08
eh, not exactly cheap, this one was close to $8.
But i don't mind paying that price cause I run the oil for super long and it stays clean, win/win.
this is the "high quality" fram filter, lmao. oxymoron for you there. laugh.gif
My F/S Thread!
Ferdi says (11:29)
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 2nd, 2024 - 10:50 PM
