> ecu
post Aug 24, 2009 - 5:59 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
i have a 97 celica gt and my ecu is gone so i was wondering would i be able to use a 99 ecu. My cluster also got messed up i have a manual celi so does it matter if i get an automatic cluster.
post Aug 24, 2009 - 6:09 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Yeah you can use a 99 ECU, so long as it is a manual ECU. And I believe you can use an auto cluster, but the automatic clusters have a gear select section where the manuals don't. I believe they'll work fine either way.
This post has been edited by 95CelicaST: Aug 24, 2009 - 6:11 PM
**** Photobucket
post Aug 24, 2009 - 6:41 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
thanks for the help i appreciated it
post Aug 24, 2009 - 7:05 PM
QUOTE (95CelicaST @ Aug 24, 2009 - 7:09 PM) *
Mine doesn't, unless that's a '99 thing?
post Aug 24, 2009 - 11:05 PM
95CelicaST
Joined Feb 5, '05
Maybe it is just the ST202 gauges. Those are the only automatic clusters I've seen, but a quick google search didn't provide any GT or ST auto clusters, so I assume they're the same and retract that aspect of my statement.
**** Photobucket
post Aug 26, 2009 - 8:51 AM
solidxsnake
Joined Apr 20, '09
QUOTE (SwissFerdi @ Aug 24, 2009 - 8:05 PM) *
Not in the USDM ones. Some pics in the interior/electrical section has pictures of a cluster that has a gear-select section in the third section, the one with the the fuel/temp gauges. I can't find it atm.
~Moving on to a 2002 Corolla S~
R.I.P Tom Celica - 1994-2010
post Aug 27, 2009 - 9:39 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
I ended up putting a 99 and 96 ecu and still doesnt work so that means i have to get a 97 ecu?
This post has been edited by babysupragt: Aug 27, 2009 - 10:01 PM
post Aug 28, 2009 - 12:40 PM
solidxsnake
Joined Apr 20, '09
QUOTE (babysupragt @ Aug 27, 2009 - 10:39 PM) *
Are you using the correct ECU? For instance, there's a diff ECU for the 5S and the 7A, are you using the correct one?
post Aug 30, 2009 - 8:22 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
im using a 5sfe
post Aug 30, 2009 - 9:01 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
is there any links i can go to. To see if i can find one
post Sep 2, 2009 - 5:13 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
finally i found a 97 ecu with the same part number but i was told that i would have to program it to my car. I was wondering if thats true can anybody help with this
post Sep 2, 2009 - 6:48 PM
same part #, should be plug and play.
post Sep 3, 2009 - 12:40 PM
babysupragt
Joined Jun 24, '06
From Houston.TX
thanks for the help
Lo-Fi Version Time is now: January 10th, 2025 - 5:10 AM
