> boost leak?, not getting any boost :(
post Aug 31, 2009 - 4:42 AM
mickwheelz
Joined Apr 26, '09
From Australia
so i have finished (maybe) my 5sfte conversion... when i fire it up, it runs and the boost gauge shows a manifold vacuum at idle.... but then when i rev it, it hits 0psi and goes no further...
It is also making a whistling sound (which would indicate a leak?)
any ideas?
ST184R - Project 5S-GTE - Audio: Eclipse CD4000, SW7200, XA1000, SC8265, EA2000 Engine: Greddy eManage, 360cc Injectors, CT26, FMIC, Walbro 255, K&N Pod, Blitz MSTT, HKS SSQV, 3SGE Head Swap, Suspension/Brakes: craftz coilovers, Gen 3 Camry Hub Swap Wheels: ROH Boost-R 17x7 - Times: N/A: 16.73, FI: Coming Soon
NCP91R - Almost JDM - Audio: Eclipse SW7200, XA1000, Jaycar LLC Engine: Resinator Removed Exterior: Domo toy, Foglights Wheels: 15in Steelies Times: N/A: Coming Soon
post Aug 31, 2009 - 12:07 PM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
QUOTE (mickwheelz @ Aug 31, 2009 - 5:42 AM) *
any ideas?
check your piping.
‹Superaison› i'm a computer inclined guy..
‹Superaison› or girl. idk what gender I am anymore.
‹SeverX13› *facepalm*
suprakid: o sh!t
suprakid: i wanna get an obama chia pet
SeverX13: hahahahaha
post Aug 31, 2009 - 12:10 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Check for leaks...probably your issue. Also, if you're just revving your car from idle you probably wont see any boost on the gauge.
post Aug 31, 2009 - 1:42 PM
any ideas?
You do realize you need to drive the car under load to make boost, right?
post Aug 31, 2009 - 2:21 PM
95st-celica
Joined Mar 29, '07
From Philly
yea reving it it will not make boost...throw it in 3rd on the highway and romp on it...see what its reading...then report back...i know i have a boost leak somewhere...i just have to rip apart my pipeing again and tighten everything up, and go over my vac lines once more. mine is making a loud hissing noise under boost and it doesnt feel as powerfull as it use to be in 4th and 5th
1988 Dodge Aries K (sold)
post Aug 31, 2009 - 5:25 PM
mickwheelz
Joined Apr 26, '09
From Australia
probably should clarify... it was not making boost under load either... i did take it for a brief drive, took it to 4-4500 rpm, and still nothing.
i have gone through and checked all my piping and it all appears to be secure... could perhaps the wastegate flap be stuck open?
post Aug 31, 2009 - 7:47 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Could definitely be your wastegate. If you aren't making any boost at all under load then you must have a pretty big leak somewhere or your turbo is lame smile.gif I would suggest making a leak tester or buying one online...I myself need to invest in one. Good luck with your search.
post Aug 31, 2009 - 10:20 PM
mickwheelz
Joined Apr 26, '09
From Australia
I will fool arround with the wastegate and take it for a spin, if that does not solve the issue i will make a boost leak detector.
Lo-Fi Version Time is now: November 28th, 2024 - 9:43 AM
