5 mins in the wet at castle combe |
Sep 27, 2009 - 4:05 PM |
Enthusiast Joined Apr 20, '06 Currently Offline Reputation: 0 (0%) |
hey folks, just been thinking about the good old days and came across this vid, just 5 mins from a wet track session at castle combe in england, the car your riding in is my freinds integra type-r, were both on semi slicks in the wet, and lapping in a different league compared to anyone else on track at that time, hopefully you enjoy watching a gen 6 pulling away, check some of the angles, whats understeer?? i was on worn r888 semi slicks, one of the best times i ever had in that car
http://www.youtube.com/watch?v=Jc1qoDCcVUY |
Sep 30, 2009 - 7:39 AM |
Enthusiast Joined Jun 18, '08 From Monaghan, Eire Currently Offline Reputation: 1 (100%) |
Awesome!!!!
You said before about gear ratios in one of your previous posts, did you put a different final drive in your gearbox? Good luck with the gen 3 by the way! |
Oct 1, 2009 - 7:17 AM |
Awesome!!!! You said before about gear ratios in one of your previous posts, did you put a different final drive in your gearbox? Good luck with the gen 3 by the way! thanks When i decided the body of my ss3 had had enough! and decided to move on to what ended up being my gen 3, i was dismantling an e56 gearbox, i've never seen aftermarket final drives for the s54 unfortunatly so no i never ran it, but i was as i say dismantling an e56, which is the gearbox that came on early 94-95 jdm ss2 gen 6's with superstrut, it also comes on the 4a-gze powered toyota's and some carina's etc, very strong box, and you can get a few different final drive options for these from japan, i have a 4.9 final drive which is about 18% shorter i think, the plan was to use an aftermarket ecu ( the 1zz-fe power-fc i'd wired up ) and use the extended rev capability of the beams, increasing to about 8200 rpm at which point, peak speed in each gear would be about the same, but torque to the wheels should increase dramatically regardless of whether the ecu reveals more power or not. I've ket the box and final drive, because i havent yet ruled out another gen 6! or maybe it'll go into my gen 5!. |
Oct 1, 2009 - 8:18 AM |
Sound.
Would i be right in saying that the 4A-GE and 3S-GE gearboxes match up, due to the G? |
Oct 1, 2009 - 10:31 AM |
Sound. Would i be right in saying that the 4A-GE and 3S-GE gearboxes match up, due to the G? no the G relates to the head design, The E56 gearbox is available for both the 4a and 3s engines because theres different bellhousings that allow the box to match up to each engine its the A of the 4A-GE and the S in 3S-GE that normally dictate which boxes are compatible as thats the block code, but theres a few exceptions to the rule, such as the E56 where you have bellhousings available for both. This post has been edited by Edophus: Oct 1, 2009 - 10:34 AM |
Oct 2, 2009 - 2:52 AM |
very nice video!!
-------------------- Group buy to replicate Narrow E series transaxle parts
Oct 2, 2009 - 8:43 PM |
nice video, you pull away nicely.
ahh cool been wondering what japanese celicas had the E56 transmission in them (94/95 SS-II with superstrut) I've heard of 1 a while ago at a car dismantlers for sale, but how rare are they?? came with a viscous LSD and an oil cooler. heres a comparison of them aswell ...............S54...... E56........ E154 (GT4) Reverse -3.153... -3.583..... -3.545 1st........ 3.285..... 3.538 ..... 3.380 2nd ....... 1.960 .... 2.045 .... 1.910 3rd........ 1.322 .....1.333...... 1.260 4th........ 1.028..... 1.028...... 0.920 5th........ 0.820..... 0.820...... 0.730 Final Drive 3.944.... 3.944...... 4.290 -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 8:59 AM |
