> Cusco Strut Bar Questions
post Oct 12, 2009 - 9:15 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
Does a ST202 Cusco strut bar fit on a ST204? I think I heard some guy's hit the brake fluid and another guy's hit the AC?
Also, can I put the stock brace on top of it like Magic did:
post Oct 14, 2009 - 9:32 AM
Promasta
Joined Oct 2, '07
bump. need this info quickly.
post Oct 14, 2009 - 9:42 AM
RoyO
Joined Jan 8, '09
From Netherlands
QUOTE (Promasta @ Oct 13, 2009 - 4:15 AM) *
I'm sorry, dunno
Yes, without any problems
post Oct 17, 2009 - 5:44 PM
Promasta
Joined Oct 2, '07
boimp. anyone seen a cusco bar over a 5sfe?
post Oct 19, 2009 - 11:46 AM
yellowchinaman
Joined Aug 11, '08
From London
It should be fine as the raised rod is only to clear the charge cooler and throttle body.
However the rod may be pressing on the hood if you have a non GT4 hood.
post Mar 4, 2010 - 12:51 AM
TRD-ST204
Joined Sep 26, '04
From Sacramento, California
I have a Cusco OS Type for a ST202 on my GT and the only thing it really gets in the way of is the A/C lines and power steering hose. It is an easy fix though I just filed down the bracket holding the A/C line so I can move it down slightly. As for the power steering hose, I moved the foam padding on the hose lower so it doesn't rub the bar. Besides these two things there aren't anything else obstructing the strut bar. By the way I don't have ABS so there are no brake lines that may or may not be in the way. Also the strut brace in the pictures is the bar for the ST205 and not ST202 (there is a difference). I hope this helps!
This post has been edited by TRD-ST204: Mar 6, 2010 - 1:16 AM
post Mar 4, 2010 - 4:46 AM
kavy
Joined Aug 8, '09
From Fiji
OMG!!i saw this in a 1996 gt-four i went to check out just today!!!it had the same cusco bars on the rear too(in the trunk).
This post has been edited by kavy: Mar 4, 2010 - 4:53 AM
post Apr 4, 2011 - 8:43 PM
Black-ST202
Joined Mar 1, '09
From Norway
Tried to put a Cusco front strut bar onto my ST205 and it hits the break fluid canister. So in my case it needs adjusment's kindasad.gif But this is somthing i bought from a ST202 owner could be the reason it wondt fit.
post Apr 4, 2011 - 11:41 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Snapshot had to mod his hood
post Apr 5, 2011 - 1:02 AM
azian_advanced
Joined Apr 18, '05
From Calgary
they're designed for rhd since the rhd brake fluid reservoirs are shaped differently.
Lo-Fi Version Time is now: November 28th, 2024 - 1:59 PM
