> general question regarding my 95 with 92K
post Oct 14, 2009 - 1:46 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
Ok, long story short I just got this 95, from a private owner with 91 k, clearly she didn't drive it much but she didn't up keep it too much but whatever, (it has been sitting most of its life) i got it for half of the blue book value. I took it to my *really good* mechanic and he did a full run down on it full mait, fluids all that good stuff.
he did a compression test and said its pretty good 132lbs, he did say the spark plugs did show some ash and he wants me to bring it back in 3,000 miles to check them again he said that he thinks *one of the cylinders might be having issues or it could be "sticky valves", its consuming oil at an abnormal rate and gas mileage is not what it should be, this may be due to the cylinder not performing,( i'm only generally mechanically inclined, no expert). Anyhow, the car runs and drives excellent , no issues there just looking for any feeback or advice anyone might have regarding the mechanical status.
2nd point, a man I work with is in auto school and said that in jan i can submit my car to his class to work on for free ( i just have to buy parts) and he said they will do a complete valve job, etc to get the car up to par.
Just wondering if anyone thinks I will need a valve job right away ?
This post has been edited by 2celicas2love: Oct 14, 2009 - 2:00 AM
The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd
95 st, swapped 3sgte 3rd gen wrc version :D
post Oct 14, 2009 - 1:58 AM
johnnehh
Joined Aug 5, '09
From Oakley, CA
So wait... What's your question?
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
post Oct 14, 2009 - 2:01 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
yea that might help right, question is do you think I will need a valve job right away or can it wait ? if so how long?
post Oct 14, 2009 - 2:04 AM
johnnehh
Joined Aug 5, '09
From Oakley, CA
It depends.
What's your gas mileage looking like?
If it's not your dd, and you don't mind it, I would just have it done when funds let you.
Ask your mechanic though. Bring it in in 3,000 miles and ask him if it absolutely necessary.
post Oct 14, 2009 - 2:22 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
my gas mileage is around 21-ish on street quite possibly less if i recall I really need to clock it again , my 94 got 26-28ish? street frown.gif, i can use my 00' as DD as it has zero problems and AMAZING gas mileage but i love driving this one much more, I guess it's not really an issue bc i only drive 7 miles to work one way .... It could be that i am so used to the amazing gas mileage on the 00 that this one seems like so much more less.
post Oct 14, 2009 - 2:35 AM
johnnehh
Joined Aug 5, '09
From Oakley, CA
Whoa. That's low. Mine gets 27 mpg, and I'm a very 'spirited' driver.
I'd definitely have it looked at. Our cars should not be getting below 25 mpg.
post Oct 14, 2009 - 2:39 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
Yea that's what i thought well I'll clock it one more time thanks for your help smile.gif
post Oct 14, 2009 - 5:46 AM
trdproven
Joined Aug 2, '05
From Guam
as long as that person kept up with oil changes, with that low mileage, it should be good. I wouldn't worry about it unless you feel something significant about it when driving it.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 14, 2009 - 8:35 PM
FWIW, I get over 30 in the city.
post Oct 26, 2009 - 12:56 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Try doing a tune up (spark plugs, leads, distributor cap and rotor) and then see how your fuel consumption is as you will have to do them after a valve job eventually anyway.
post Oct 26, 2009 - 1:03 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
QUOTE (Euphoria @ Oct 26, 2009 - 1:56 AM) *
post Oct 26, 2009 - 2:15 AM
Hanyo
Joined Aug 16, '03
From Bay area
from the sound of it, it sounds like you have a leaking valve seal.
From my understanding it does not harm the engine to drive the vehicle with a leaking valve seal. The only problem you will have is fouling out spark plugs and require replacing them more frequently.
But as always, preventative maintenance 100x cheaper then repairs.
Driving now with leaking valve seals will:
1) contaminate your catalytic converter (about 250 dollars in california because all cats sold in california must have a serial number)
2) ruin your oxygen sensor (generica oxygen senser is around $70 for generic or $150 dollars from toyota)
3) lead to a ton of carbon deposit on your valves (this can lead to valve seat failure and possible require a new engine head $1500 because of labor)
Those are just a list of possible problems with running a car that burns oil.
But from my own experience with dealing with burning oil cars, You generally can drive them for many years without problem. However once you notice a problem it will require replacement of the entire engine.
just my 2 cents.
QUOTE (johnnehh @ Oct 14, 2009 - 12:35 AM) *
my car gets less then 25 all the time. The main reason is because I do a lot of short trips and majority of the time the engine is idling at a traffic light or warming up on my drive way.
Lo-Fi Version Time is now: February 22nd, 2025 - 2:11 PM
