> Crankshaft pulley/balance harmonizer
post Oct 15, 2009 - 1:55 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
Need to take it off. How do I get the bolt off? Figure a breaker bar and something else to hold it in place. But how?
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Oct 15, 2009 - 6:02 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
you can put a breaker bar on it and crank the motor (pull the ecu fuse so it doesnt fire)
you can use a rattle gun
you can man up and use your guns tongue.gif (arms incase you dont get that)
use an extension on your breaker bar if its needed.
also give the head of the bolt a few taps with a hammar to help it loosen.
GRX133 Toyota Mark X 350s
post Oct 15, 2009 - 10:24 PM
azian_advanced
Joined Apr 18, '05
From Calgary
if you have a bolt that fits the small hole on the pulley, you can use it to keep it steady.
post Oct 16, 2009 - 1:54 AM
Cuts_the_Pilot
Joined Dec 15, '02
be careful doing that, if its really tight and you crank on it the bolt will break as they are only an m8.
post Oct 17, 2009 - 12:25 PM
CaliJeff
Joined Apr 22, '07
Got it. I used a chain wrench and a Breaker bar. Bolt came out easy after I loosened the power steering pump belt bracket. Then to take off the pulley, I used a pulley extractor. Easy as cake when u got the right tools wink.gif
Lo-Fi Version Time is now: January 10th, 2025 - 3:21 PM
