> Antifreeze, where to buy it?
post Oct 29, 2009 - 3:30 AM
Hanyo
Joined Aug 16, '03
From Bay area
Where does everyone get there toyota red antifreeze at?
My local dealer wants 22 bucks a gallon for it. Its not expensive considering you only change it every 100k miles. But I have to maintain 6+ toyota in the family and that is gonna hurt.
So does anyone know where to get some cheap toyota red antifreeze?
post Oct 29, 2009 - 11:23 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Cheap. Toyota. Pick one.
That said, try an online dealer such as 1sttoyotaparts.com, they operate out of a dealership so the parts are OEM but the prices involve less overhead.
post Oct 30, 2009 - 12:06 AM
Hanyo
Joined Aug 16, '03
From Bay area
i heard car quest has red antifreeze but i'm not sure if it is any good.
I'm not asking for bargain prices on antifreeze, Just cheaper then 22 dollars a gallon. I will be needing around 6 galls taht is over $100 for antifreeze.
post Oct 30, 2009 - 1:03 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Hanyo @ Oct 29, 2009 - 10:06 PM) *
i think i saw in car quest catalog that they sell toyota red coolant there.
God made man....
Everything else...
Made in China
post Oct 30, 2009 - 1:11 AM
TiGZ461
Joined Aug 6, '09
From Bergen County,NJ
Hmm so my coolant is trash? I bought Prestone thinking it didn't matter what you got. A bit late now but would this cause any issues?
1996 Toyota Celica ST 25th Anni. Edition #461
post Oct 30, 2009 - 9:21 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
You're fine. Standard green coolant is all I ever use.
**** Photobucket
post Oct 30, 2009 - 7:52 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (TiGZ461 @ Oct 29, 2009 - 11:11 PM) *
coolant is coolant.
All it does is:
1) keep different metals from reacting to water causing corrosion.
2) keep water from freezing
3) lubricate the water pump
saying that, there are different schools of thought about the optimum antifreeze formula.
Being a toyota fanboy I like to stick with what toyota engineers come up with.
post Oct 31, 2009 - 3:27 AM
TiGZ461
Joined Aug 6, '09
Got ya. So need to do worry, also might be a little off topic but I've been recommended something called Purple ice. I think thats what I was told don't quite remember, it had something to do with helping with the cooling of your engine. Anyone try this?
post Oct 31, 2009 - 10:22 AM
keep in mind though that you can buy straight from toyota and then mix it with distilled water 50/50. if you have toyota red then stick with toyota red or flush your system totally then change to green or something else cheaper. mixing coolant chemistrys can cause problems.
post Nov 2, 2009 - 5:11 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Mixing coolant will eventually end like this:
Gone oem headgasket:
JDM ST205
Lo-Fi Version Time is now: November 29th, 2024 - 2:26 AM
