7A oiling question, Where to tap in? |
Nov 1, 2003 - 5:10 PM |
Enthusiast Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
Has anyone installed an oil pressure gage on a 7A? Where is there a port on the block? Anybody know if its NPT or BSPP thread?
Thanks! |
Nov 1, 2003 - 5:13 PM |
I was under the assumption that it required drilling into the oil pan once it's removed to install the sensor. I plan to install an oil pressure gauge on my 4A-GE, and I think the pan has to be removed and drilled.
Nov 1, 2003 - 5:33 PM |
No, I know theres a stock oil press sensor for the oil warning light. I should be able to tee of that and make it work, I just can't remember where it is.
Nov 1, 2003 - 8:00 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
It's on the block just on the left of the header, about at half height
This post has been edited by edo17982: Nov 1, 2003 - 8:00 PM |
Nov 2, 2003 - 12:16 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
The 5sfe is NPT so the st should be the same I would think. Summit racing has a fitting.
-Bryan- This post has been edited by 1bwilson: Nov 2, 2003 - 12:17 AM -------------------- Member of Team 5sfTe
Nov 2, 2003 - 11:30 AM |
Excellent! Thanks guys.
Lo-Fi Version | Time is now: December 1st, 2024 - 4:24 AM |
