> Picking the right wheel spacers, which one to choose?
post Dec 4, 2009 - 5:00 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Just got word that FatLace/HellaFlush might be having HellaFlush 4 in Hawaii. I've been putting off getting wheel spacers with the hubcentric ring (not the knock off ones with no hub ring) for a very long time. First i was gonna get them for the GTS rims. Now I'm running my 18's daily, so which one should I get? Both are hubcentric for 54.1 centerbore on the celica. Version 1 comes with extended studs that you put in place of your stock ones. Or version 2 that has studs in the spacer itself and special gold nuts laugh.gif that fasten down your stock studs. V.2 seems to be the easier one to install, V. 1 seems to be safer cuz it's 1 lond stud. I'm only showing the brand Ichiba because they're the only one that's certain to have the extended studs for v.1 (hubcentric) or what v.2 has(lug centric).
sooo.........here's version 1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWAX:IT
and version 2
which one?? Now for the last question what size?? 10mm, 15mm or 20mm. I have 5mm rings that make the rim......so so. Should I get the 10mm and try it out first then go 15mm if I don't like it? or go straight the 15mm and camber the heck out of wheels to be somewhat within safety check wink.gif Either way I HAVE TO raise the car a little in order to stay within Hawaii's Road law "Rim diameter can be any size, but it must be inside of the wheel well."
and yes i did read this:
http://www.6gc.net/forums/index.php?showtopic=69919
.............all of it biggrin.gif What would Harold_Fastwaker pick?? laugh.gif
This post has been edited by 808celica: Dec 4, 2009 - 5:11 AM
post Dec 4, 2009 - 10:05 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
Well, go take a ruler and measure from your wheel lip to your fender distance. Doesn't need to be perfect just a rough estimate. Since I do not know your current wheel specs I cant give you exact spacer size. But if you think 15mm will poke to much and need a good amount of negative camber then get the 10mm. Try to keep it as close to 0 camber as possible and raise the car back up a bit to even out the whole look.
so, I forgot to add, go with option 1 for spacers.
This post has been edited by Harold_Fastwaker: Dec 4, 2009 - 10:07 AM
post Dec 4, 2009 - 3:31 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Hmm kk I'll get the version 1 15mm v2 20 and 25mm. I measured it and to where i want my wheels to me i need 25mm spcers wink.gif a little more agressive than what most will do.
**found H&R 25mm spacers they only have the lug centric style which im fine with**
Now that i look at it Im more into changeability cuz i know i might want them off and on constantly. Thanks Harold for you input. I guess im goingto have almost $800 worth in spacers laugh.gif just to change up the looks constantly
This post has been edited by 808celica: Dec 4, 2009 - 4:20 PM
post Dec 4, 2009 - 5:50 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Nerd. Just buy wheels that fit.
That's one great thing about the MR2. Many places sell staggered wheels with flush offsets for MR2s.
**** Photobucket
post Dec 4, 2009 - 6:01 PM
manphibian
Joined Oct 13, '06
From UK
As long as you get longer studs, and go with a recognized make, like H&R you will have no problems.
If you go cheap, you will be in danger of losing a wheel, damaging suspension and bearings and losing a crapload of performance due to the extra weight that you have to rotate....
post Dec 4, 2009 - 7:54 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (95CelicaST @ Dec 4, 2009 - 12:50 PM) *
laugh.gif I like these wheels though.
QUOTE (manphibian @ Dec 4, 2009 - 1:01 PM) *
Fo sho' Boss thumbsup.gif some auctions said that the extended studs only vary with car make/model. I did ask the seller though if the celica spacers for H&R he's selling has the extended studs.
post Dec 4, 2009 - 10:16 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (manphibian @ Dec 4, 2009 - 6:01 PM) *
I am going to put this out on the table. Those of us who go as low as possible with flush wheels and no wheel gap dont care about performance. That was tossed out the door long ago. biggrin.gif
post Dec 4, 2009 - 10:55 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
performance isn't affected by 1 pound spacers
you only feel it on no torque civics or integra, if you know enough your car to feel it
each pound added in rotational resistance is equivalent to 3 static pound
our car weight is like 1000 times more than these spacers, so if you convert that to rotational resistance (3), you add like 15 pound max.
the big difference of rotational weight is seen when adding 8 pound per wheel when swapping to bigger wheels. In this case you add like 100pound to the vehicule
post Dec 5, 2009 - 2:59 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Harold_Fastwaker @ Dec 4, 2009 - 5:16 PM) *
post Dec 7, 2009 - 7:20 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
whut is hellaflush.......and whut r these spacers for?....... sry its new to me but i may have a little bit of an idea....
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post Dec 7, 2009 - 11:33 PM
epocsirhc
Joined Nov 8, '08
From Penn Valley,Ca
check this out http://fatlace.com/hellaflush/
post Dec 8, 2009 - 1:28 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
ok im gettin the idea.....how does the suspention work with all this? must be real stiff? ......so spacers r for the ones who wanna keep their current rims and flush them?.......
feedback
feedback
post Dec 8, 2009 - 8:17 AM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (Dragondog @ Dec 8, 2009 - 12:28 AM) *
suspension has nothing to do with it unless the rims are extended far enough to rub against the wheel arch. but with spacers, i can see that there will be more stress on your wheel bearings.
post Dec 8, 2009 - 4:22 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (azian_advanced @ Dec 8, 2009 - 8:17 AM) *
almost. Suspension has a lot to do with it. Need adjustable springs at minimum to lower the car as far as possible for the look, then you will need to run them fairly stiff to keep from rubbing or actually having the tires slam into your fender. Then either buy proper offset wheels or use spacers to fit the wheels to how flush you want them.
post Dec 9, 2009 - 3:31 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
by job i think i got it...lol......anyway......how do i measure from what to what with what to know what size offset i want
i looked at ur guide and it looks that the back is gonna be a diff offset then front.........so that means rotating tires would look funny
This post has been edited by Dragondog: Dec 9, 2009 - 3:43 AM
feedback
feedback
post Dec 9, 2009 - 5:41 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE (Dragondog @ Dec 9, 2009 - 3:31 AM) *
not necessarily. If you run 17x8 wheels with 30 offset on all 4 corners then your spacers will adjust for the flushness. You can still rotate your tires. But if they have different offsets to begin with then that is a non tire rotating wheel set. Same thing like I have, 8.5 up front 9.5 in rear. No tires can be rotated.
post Dec 9, 2009 - 5:57 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Harold_Fastwaker @ Dec 9, 2009 - 12:41 PM) *
another reason why i wanna flush my wheels and not get another set. Normally rims people buy for these cars have a 30-35 range offset so GET 25mm spacers!!!!!! laugh.gif
post Dec 10, 2009 - 5:18 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
my thoughts are to try and do this without useing spacers.........possible with 16x7 50 or 45.........or 17x8 45...........what would be better performance wise.......or is what im askin basicly tring to start fire with water.....they dont mix
This post has been edited by Dragondog: Dec 10, 2009 - 5:23 PM
feedback
feedback
post Dec 10, 2009 - 5:49 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Dragondog @ Dec 10, 2009 - 12:18 PM) *
is the 50/45 the series of the tire or your offset??
16x7wheels w/ 205 or 215/45/16 tires with lets say 5+offset should give you the look. keep in mind though the lower your offset and the wider the rim the more chance you have to rub on something. A Tein S-tech spring drop or 1.5-2in drop should be safe IMO.
post Dec 10, 2009 - 9:27 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
QUOTE (808celica @ Dec 10, 2009 - 11:49 PM) *
sry yes the 50/45 is series...not offset..........................ok so 16x7 45 with 5+ offset would be better performance wise then 17x8 45 and ? offset.........also how flush would the 5+ offset make it?.........
feedback
feedback
Lo-Fi Version Time is now: November 30th, 2024 - 6:18 AM
