wiring problems, cigaratte wires |
Jan 13, 2010 - 11:56 AM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
okay so i cut the wires got it all hooked up got a new toggle switch http://www.autozone.com/autozone/catalog/a...randName=Dorman hooke just to be able to use it right. Well for some reason when i turn it on all my lights go dim, and well as you can guess when you turn it off they light back up. Did i do something wrong, i assume i did.. need help asap thank you
Jan 13, 2010 - 4:54 PM |
Enthusiast Joined May 29, '09 From Lake Ariel, PA Currently Offline Reputation: 4 (100%) |
whats the switch for? and also that's not a normal on off switch thats a toggle switch
-------------------- Representing the Convertible Crew since 2008 |
Jan 13, 2010 - 6:01 PM |
the switch is for 4 small led lights already pre strung and everything i have them in my car right now but that switch wont work, whats wrong with the switch what should i get?
Jan 13, 2010 - 6:50 PM |
that switch has just read up on different types of switches, im not too sure what toggle switch it is exactly look at that website i showed you and see which one it is and i can help.
Lo-Fi Version | Time is now: January 12th, 2025 - 9:51 PM |
