> Fog Light Units, I Want To Buy Soon
post Jan 15, 2010 - 1:46 PM
CelicaST96
Joined Aug 23, '09
From Ohio
If anyone has a set of fog lights , send pictures if you would. I would like to buy a set because my car never came with them and I'm going with the full H.I.D. look with lights. I will need everything needed from the units, to the wiring and then a switch of some sort to turn them on inside of the car. I don't know if I either eventually will turn them on from the regular lights switch or install a switch where underneath the steering wheel there is rectangle on both right and left sides. I figure that is where a switch goes and you cut that plastic out. If you can explain to me how to set up the fog lights, I also will appreciate that as well.
Thank You
Seth(CelicaST96)
Lo-Fi Version Time is now: November 27th, 2024 - 6:11 AM
